Problems with clients on a 1220 AP with LEAP auth
I am having some problems with all clients on one access point that have this state:
0018.de99.bafe 0.0.0.0 4500-radio TN1AP01OFF self EAP-Assoc
Here is the config:
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname xx
logging buffered informational
aaa new-model
aaa group server radius rad_eap
server 10.1.50.160 auth-port 1645 acct-port 1646
aaa authentication login default group tacacs+ local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization exec default group tacacs+ local
aaa session-id common
enable secret 5
username imperbalene privilege 15 secret 5
clock timezone CST -6
clock summer-time CST recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
ip subnet-zero
ip domain name accuridecorp.com
no dot11 igmp snooping-helper
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode wep mandatory
ssid accuwireless
authentication open eap eap_methods
authentication network-eap eap_methods
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
rts threshold 2339
rts retries 32
power local 100
packet retries 32
channel 2462
fragment-threshold 2338
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
description bvi1
ip address 10.150.0.101 255.255.0.0
no ip route-cache
ip default-gateway 10.150.0.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/iv
ip http authentication aaa
ip radius source-interface BVI1
logging trap debugging
logging 10.1.50.5
snmp-server community diff133>>// RO
no snmp-server enable traps tty
snmp-server host 10.1.50.5 diff133>>//
tacacs-server host 10.1.50.160 key
radius-server host 10.1.50.160 auth-port 1645 acct-port 1646
radius-server retransmit 3
radius-server key 7
radius-server authorization permit missing Service-Type
radius-server vsa send accounting
radius-server vsa send authentication
I have a Cisco ACS server on the backend authenticating just fine, but it seems either the clients are misconfigured or there is something in the AP that needs to be changed.
1 REPLY
Re: Problems with clients on a 1220 AP with LEAP auth
What is the behavior you're seeing?
1.) The client shows up in the association table on the AP, so WLAN configs must match.
2.) ACS shows a passed authentication? So the clients have an appropriate IP address and are able to pass traffic...
Can you ping the GW of the network?
137
