Public wlan consult...
Hi, I'm about to buy a Cisco Aironet AP in order to buil up a wlan. Because the network will be public, i need to know how to deny any relation between the computers connected (access to shared folders, ping, map, etc...).
In other words, a network with computers thar must not have any relation between them...
How can I implement that?
sorry about my english.
rgds
Re: Public wlan consult...
If you implement layer 2 isolation this will prevent any wireless client from Communicating to any other. This feature is often used in a public hotspot situation.
Hope this helps
Cheers
Mark
*Pls rate all useful posts
Green
You would enable "Public Secure Packet Forwarding" (PSPF).
PSPF will prevent any device associated with a given AP from accessing (directly) any other associated device through that AP.
It's a checkbox in the WebGUI under the SSID screen.
It can also be enabled from the CLI, but I don't recall the command, and I don't have access to my references.
Good Luck
Scott
112
