QOS Policy gets Policy hits but doesn't seem to do anything when put to the test
I have been trying to implement a policy that prioritizes certain types of of traffic over another namyly Lync Voice Traffic, Cisco CAPWAP traffic from controllers to AP's, and Citrix ICA Traffic.
I do recieve policy hits but when I load the connection up with say copying a file the policy seems to not work. This is on a 1921 router.
I will include the config as I may be doing somthing wrong.
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius local
aaa session-id common
ip cef
ip domain name pmp.local
no ipv6 cef
username XXXXXXXXXXXXXXXXXXXX
ip ssh time-out 60
ip ssh version 2
class-map match-any CAPWAP
 match access-group 104
class-map match-any LYNC
 match access-group 103
class-map match-any CITRIX
 match protocol citrix
 match access-group 110
policy-map OUTBOUND
 class LYNC
  priority percent 25
 class CITRIX
  priority percent 50
 class CAPWAP
  priority percent 20
 class class-default
  shape average 20000000
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.1
 description LAN Facing
 encapsulation dot1Q 1 native
 ip address 172.16.27.254 255.255.255.0
 ip helper-address 10.128.4.48
 ip helper-address 10.128.4.20
 ip helper-address 172.16.27.79
 no ip redirects
 ip flow ingress
interface GigabitEthernet0/0.5
 encapsulation dot1Q 5
 ip address 172.16.127.254 255.255.255.0
 no ip redirects
 ip flow ingress
interface GigabitEthernet0/0.50
 description ITTestVlan Interface
 encapsulation dot1Q 50
interface GigabitEthernet0/1
description PointToPoint
bandwidth 20480
ip address 10.0.27.254 255.255.255.0
 no ip redirects
 ip flow ingress
 duplex full
 speed 100
 service-policy output OUTBOUND
router eigrp 10
 network 10.0.27.0 0.0.0.255
 network 172.16.27.0 0.0.0.255
 network 172.16.127.0 0.0.0.255
ip forward-protocol nd
ip forward-protocol udp 4011
ip forward-protocol udp bootps
no ip http server
ip http access-class 23
ip http authentication aaa login-authentication default
ip http authentication aaa exec-authorization default
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 1000
ip route 0.0.0.0 0.0.0.0 172.16.27.253 200
access-list 23 permit 10.0.27.0 0.0.0.255
access-list 23 permit 172.16.0.0 0.0.0.255
access-list 23 permit 172.16.27.0 0.0.0.255
access-list 23 permit 172.16.127.0 0.0.0.255
access-list 103 remark LYNC-Priorisation
access-list 103 permit tcp any any eq 3389
access-list 104 remark CAPWAP-Priority
access-list 104 permit udp any eq 5246 any
access-list 104 permit udp any any eq 5246
access-list 104 permit udp any eq 5247 any
access-list 104 permit udp any any eq 5247
access-list 110 remark Citrix-Priorisation
access-list 110 permit tcp any eq 2598 any
access-list 110 permit tcp any any eq 2598
access-list 110 permit tcp any eq 1494 any
access-list 110 permit tcp any any eq 1494
snmp-server enable traps entity-sensor threshold
radius-server host 10.128.4.20 key XXXXXXXXXXXXXXXXXXXXXXXXXX
control-plane
Everyone's tags (1)
1 REPLY
Super Bronze
duplicate post
duplicate post
60
