11-02-2010 04:38 AM - edited 07-03-2021 07:21 PM
Hi ,
Need one help from you.Please let me know Cisco WLC 2006 ( Running version 4.2.207) will support Access Point 1242AG ?
Thanks in advance.
Thanks & Regds,
Lalit
Solved! Go to Solution.
11-02-2010 06:53 AM
HI Lalit,
Due to this statement in the relasenote of your release I think it will supports the 1242.
CSCsy76954—Cisco 1242 access points might generate the following traceback:
-Sebastian
11-03-2010 01:56 AM
The support of APs is release-based.
5.0 and later dropped the support for AP 1000 series (1010,1020,1030)
4.2 supports all APs except (in the new ones) 3500,1260,1140,1040
So yes it will support 1240 for you.
Nicolas
Please rate answers that you find useful
11-02-2010 05:06 AM
Hi Lalit,
the AP supports LWAPP, so he can joint the WLC.
These Cisco Aironet AP platforms are able to run LWAPP:
regards,
Sebastian
11-02-2010 05:35 AM
Hi Sabastian,
Thanks for your reply.My question was I have a Wireless Lan Controller 2006 with 1030 Access Points registered to that and i wants to add AP1242AG.The Current version running on WLC 2006 is 4.2.207.I wants to add 1242AG Access Point to the 2006 WLC.Will my current WLC with current running version of image will support AP1242AG ?
Please reply.
Thanks & Regds,
Lalit
11-02-2010 06:53 AM
HI Lalit,
-Sebastian
11-03-2010 02:13 AM
Hi Sabastian,
Thanks for your suggestions.Will it also supports AP1252.
Thanks & Regds,
Lalit
11-03-2010 01:56 AM
Nicolas
11-03-2010 02:15 AM
Hi Nicolas,
Thanks for the clatification.Will it also supports AP 1252.
Thanks & Regds,
Lalit
11-03-2010 02:24 AM
Yes it will.
