07-12-2013 03:03 PM - edited 07-04-2021 12:24 AM
Hi All,
I have some queries regarding mobility configuration. I have to two WLC's; one Cisco 5508 & another Cisco 4402. My queries are:
1. I have configured both the WLC's in same Mobility domain & same Mobility group but with different Management IP segment. Will they be considered within the same mobility group or they will work as if they are the part of different mobility group?
2. Currently I have 100 AP license on WLC 5508 & 50 AP license on 4402. I am having more than 50 AP's in my network & all are registered with WLC 5508 since it is the primary. I want only selected 50 AP's to register with WLC 4402 in case WLC 5508 goes down. Is there any way I can achieve this?
Shahab
Solved! Go to Solution.
07-12-2013 03:59 PM
Yes... As long as there is connectivity between the two WLC and the ports udp 16666 and IP97, the mobility should be up.
Depending on the code in the WLC, you can set the priority to the AP in the high availability. So the 50 AP's you can set them higher than the other 5.
07-12-2013 04:03 PM
Since all your APs are registered to one controller, any roaming will be Layer 2, hence no change in IP address of the client. If you want certain APs to fail over to from the 5508 to the 4402, then you can specify the 4402 controller name and IP address as Secondary controller on the designated APs of your choice.
07-12-2013 03:59 PM
07-13-2013 08:49 PM
Scott you gave a nice explanation.
07-12-2013 04:02 PM
07-12-2013 04:03 PM
