Question regarding the 1242AG with Antenna
I am trying to connect 1242AG with the Cisco Multiband Diversity Omnidirectional
Ceiling-Mount Antenna (AIR-ANTM4050V-R)which got two connection. Should I connect two primary (2.4Ghz and 5ghz) or should I connect both on 2.4ghz) we use 2.4ghz mainly
1 REPLY
Hall of Fame Super Silver
Re: Question regarding the 1242AG with Antenna
If you require the need for the 2.4GHz vs the 5GHz, then use the antenna for the 2.4GHz and not the 5GHz. This way you can still use diversity. If you require the use of the 5GHz, then I would suggest you purchase another antenna.
-Scott
133
