Community Member
Radio going to blocking state
Hi All
The Cisco 1200 WAP, when logged shows me the fowarding state as Blocking.
When the carrier test is run, it shows me as busy. Can any one tell me shat can be the cause.
I suspect the STP should be the issue here.
Vijay
1 REPLY
Silver
Re: Radio going to blocking state
Use the resetall command to reset the radio interface. Upgrade the bridge
118
