Community Member
Radios on 1242AG stay down with Injector and Cat6509
Dear all,
i noticed that the 1242AG does not bring up the Radios, when there is a Power Injector connected.
I see in the Logs of the AP:
%CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C6509 <Switchport MAC Add>
The Module in the 6500 is a   WS-X6348-RJ-45
The Option "Power Injector installed" on the WLC is also enabled, with the MAC Address from the Switchport, but no change.
When i disable CDP on the mentioned Switch Port and reload the AP, it comes up and runs fine.
Any ideas, what is causing this problem?
BR.
stefan
Hall of Fame Super Silver
Re: Radios on 1242AG stay down with Injector and Cat6509
Isn't there another option on the wlc in regards to the power. IIRC, there are two options, try checking the other option.
-Scott
Community Member
the other option is "override" in the field "Power Injector State".
but this didn't change the problem.
Hall of Fame Super Blue
What is the WLC firmware?
Community Member
WLC Soft is  7.0.116.0
AP Soft is  12.4(23c)JA2    / Boot Version 12.3.7.1
Is this the only WAP that's having a problem or are there more.
If this is the only WAP then check your cables.
Community Member
yep, this is the only one.
will check the cables.
Highlighted
Community Member
problem fixed, with replacing the power supply and cables.
612
