Radius authenticaation and local EAP authentication
Does any body knwos if it´s possible to use radius server authentication for one WLAN and local EAP authentication for a second WLAN?
I´m trying to configure it, but the WLAN using local EAP doesn´t accept the local user and password,
thanks for your help.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
On the WLAN itself, you
On the WLAN itself, you define the priority for radius or local. So if you don't define AAA Servers in a WLAN but enable local eap, the WLAN will use local eap.
So the answer to your question is yes, you can define either.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_0110010.html
Also, v7.4.121.0 is what I would upgrade to.
Scott
-Scott
VIP Purple
What code are you running on
What code are you running on your WLC ?
Rasika
7.4.110.0 on a 5508 WLC
Scott
-Scott
52
