Rapidly increasing output drops on Dot11Radio interface
Hello all,
Our monitoring system detected rapidly increasing output drops on Dot11Radio interface for 3 Access Points at a customer site. Here is the simplified output confirming it from the AP:
AP-1#sh int do0 | i drop
  Input queue: 0/1127/351/0 (size/max/drops/flushes); Total output drops: 1719738176
  Input queue: 0/1127/351/0 (size/max/drops/flushes); Total output drops: 1719738384
  Input queue: 0/1127/351/0 (size/max/drops/flushes); Total output drops: 1719738466
  Input queue: 0/1127/351/0 (size/max/drops/flushes); Total output drops: 1719738616
  Input queue: 0/1127/351/0 (size/max/drops/flushes); Total output drops: 1719738686
  Input queue: 0/1127/351/0 (size/max/drops/flushes); Total output drops: 1719738770
  Input queue: 0/1127/351/0 (size/max/drops/flushes); Total output drops: 1719738828
  Input queue: 0/1127/351/0 (size/max/drops/flushes); Total output drops: 1719738900
The above commands were executed 1 second from the previous one.
Here's the interface config:
AP-1#sh run int do0
Building configuration...
Current configuration : 504 bytes
interface Dot11Radio0
no ip address
no ip route-cache
ssid HW-WLAN
no short-slot-time
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0
no preamble-short
channel least-congested 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457
station-role root
rts threshold 2312
no dot11 extension aironet
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
end
Can someone please suggest where do I start troubleshooting this?
Hall of Fame Super Gold
Hmmm ... 2.4Ghz radio.
Could be cause by a few things:
1.  Channel interferrence; or
2.  Weak signal
Thanks for your reply. I don't recall anyone at the site complaining of weak wireless. How do I check it?
Re: Rapidly increasing output drops on Dot11Radio interface
On the WAP, use the command "sh dot11 assoc" will tell you the client, run the command again but at the end enter the MAC address of the client and look under "Signal Strength".  You want a low negative number.  Anything higher than -75 dBm is baaaaaaaaaaaaaaaaaaaad.
Well it kept fluctuating, but I believe this one shows the average:
AP-1#sh dot11 associations all-client | i Strength
Signal Strength   : -46  dBm           Connected for    : 1771 seconds
Signal Strength   : -67  dBm           Connected for    : 14286 seconds
Signal Strength   : -35  dBm           Connected for    : 50001 seconds
Any suggestions on checking channel interference?
Commands are:  dot11 dot110/dot111 carrier busy
Results will appear in the "sh logs".
I got this in the show log
Frequency  Carrier Busy %
   2412          1
   2417          3
   2422          1
   2427          0
   2432          2
   2437          1
   2442          1
   2447          0
   2452          0
   2457          0
   2462          0
   2467          0
   2472          0
Does it make sense to you?
Makes alot of sense.  The low number on the right-hand side means that the channels are not "busy" or little interferrence.  How about the others?
Do you mean other AP's? This AP is the one showing the maximum rate of output drops. The others show much lesser than this one, so I would like to focus on this one first if its okay
I did a blog post that might help you understand carrier busy ...
http://www.my80211.com/cisco-auton-cli-commands/2010/6/20/autonomous-carrier-busy-test.html
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Excellent post. Really informative.
I typed "dot11 dot11radio0 carrier busy". Do I need to do it for dot11radio1 too?
0 is your 2.4 Ghz radio and 1 is your 5 GHz radio.
Ok I get it. 5 GHz is not being used as I see the interface is admin down
Dot11Radio1                unassigned      YES NVRAM  administratively down down
What else can I check?
Anyone having any more ideas which I can try?
Bump...
Anyone?
it's hard to say. It could be interference but without a spectrum check we cannot rule in or out that. Can you move the clients to 5ghz for a test? And this started all of a sudden? And clients are getting disconnected and slow connections?
The users haven't reported any major issues. Their connections don't drop. Any helpful links detailing how to go about checking the spectrum? I'm afraid the 5 GHz test wont be an option as its a production network.
2931
