rate-limit for some MAC on aironet 1231
Hello!
I need to set rate-limit for some mac addresses on access point aironet 1231.Is it possible?
If no, what ios or devices can do it?
Thanks.
1 REPLY
Bronze
Re: rate-limit for some MAC on aironet 1231
No there is no option for rate-limit in Aironet but in controller, Rate-limiting is applicable to all traffic destined to the CPU from either direction (wireless or wired). Cisco recommends that you always run the controller with the default config advanced rate enable command in effect in order to rate-limit traffic to the controller and protect against denial-of-service (DoS) attacks. You can use the config advanced rate disable command to stop rate-limiting of Internet Control Message Protocol (ICMP) echo responses for testing purposes.
218
