Recommended products for connection between buildings 50 meters apart
I have a client that requires a connection between their two buildings 50 meters apart. If possible they require bandwidth up to 54Mbps. Currently they only have a switch in either building.
Can anyone recommend a solution for this? Will they need two bridges or do they need 1 bridge and 1 AP?
Many thanks
1 REPLY
Bronze
Re: Recommended products for connection between buildings 50 met
In europe the best way to do this is to use a cisco 2 x 1300 if you are in the states you can use 2 x 1400. However the 1300 is more flexible.
107
