Removing LWAPP from 1231
Have a couple 1231g's that lived in a LWAPP environment but are now being re-deployed at stand alone units. Can't figure out how to downgrade or turn off LWAPP. How is this done?
Hall of Fame Super Red
Re: Removing LWAPP from 1231
Hi A.J,
These can be converted using the following method;
Using a TFTP Server to Return to a Previous Release
Note This section does not apply to Cisco C3201WMIC and Cisco C3201LAP.
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall, ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View > Show hidden files and folders.
Step 4 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, c1240-k9w7-tar.default for a 1240 series access point, and c1250-k9w7-tar.default for a 1250 series access point.
Step 5 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 6 Disconnect power from the access point.
Step 7 Press and hold MODE while you reconnect power to the access point.
Step 8 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 9 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 10 After the access point reboots, reconfigure it using the GUI or the CLI.
From this doc;
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
Hope this helps!
Rob
I can confirm that this method works for the 1140 ap also.
Hall of Fame Super Gold
Hi Andrew,
You want to convert your AP from LWAPP to Autonomous? Here's another method:
Requirements:
• Image file (such as c1200-k9w7-tar.122-15.JA.tar);
• AP is connected to the Wireless LAN Controller; and
• AP can ping the TFTP server where the image is located.
Procedures:
1. Find out what AP needs to be converted from LWAPP to Autonomous mode by entering the following command:
sh ap summary
2. Enter the following CLI command on the Wireless LAN Controller:
config ap tftp-downgrade
3. The AP will download the software and after a reboot, the AP will be on Autonomous mode.
Hope this works for you.
536
