RESET HARDWARE AP1010 Factory Default
I have 6 APs 1010 that not work properly.
The Wlan Controller don't see this APs.
The problem is that this APs have an ip address configured stored (i don't know what is the ip address) because in the old configuration the aps HAVE A IP ADDRESS fixed.
I must reset the AP to factory default and then reconnect at the LAN , WHERE IS PRESENT dchp WITH OPTION 43.
Can you help me?
fcostalunga
1 REPLY
Re: RESET HARDWARE AP1010 Factory Default
Support for the 1000 series APs is no longer provided in the WLC Code. What version of code are you running?
297
