05-11-2008 04:53 AM - edited 07-03-2021 03:50 PM
I bought an Aironet 1220A series AP. I can't get to priviledge mode and I have tried to reset the AP to no avail. Does any know the trick to reset the AP?
Here is some info about the AP:
From bootup sequence - cisco AIR-AP1220-IOS-UPGRD (PowerPC405GP) processor with 14326K/2048K bytes of memory.
Processor board ID VDF0643Q0TR
PowerPC405GP CPU at 196Mhz, revision number 0x00C4
Last reset from power-on
Bridging software.
1 FastEthernet/IEEE 802.3 interface(s)
1 802.11 Radio(s)
What's in the flash dir
ap: dir flash:
Directory of flash:/
3 -rwx 97 <date> env_vars
7 drwx 384 <date> c1200-k9w7-mx.122-15.XR2
from the sho ver command
ap>sho ver
IOS (tm) C1200 Software (C1200-K9W7-M), Version 12.2(15)XR2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 17-Sep-04 13:40 by kellythw
Image text-base: 0x00003000, data-base: 0x005E8554
ROM: Bootstrap program is C1200 boot loader
BOOTLDR: C1200 Boot Loader (C1200-BOOT-M) Version 12.2(8)JA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ap uptime is 1 minute
System image file is "flash:/c1200-k9w7-mx.122-15.XR2/c1200-k9w7-mx.122-15.XR2"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Bridging software.
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0B:46:B8:CA:ED
Part Number : 0-0000-00
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : VDF0643Q0TR
Top Assembly Part Number : 000-00000-00
Top Assembly Serial Number :
Top Revision Number :
Product/Model Number : AIR-AP1220-IOS-UPGRD
Configuration register is 0xF
05-11-2008 07:25 AM
I was able to figure out my own question - isn't that something? The answer to my problem was that I was not using the correct password for the console or the correct userid/password combination for http.
The correct password for the console is: cisco with a BIG "C" - Cisco
and for the web configuration tool it is cisco with a BIG "C" also - Cisco/Cisco.
