Community Member
Restricting WLANS on APs - LWAPP - WISM
so if i make multiple wlans on a controller, all the APs on that controller get them? Is there a way to restrict which APs can get which wlans? I have wcs also if i need this - running h-reap
Community Member
Re: Restricting WLANS on APs - LWAPP - WISM
the feature wlan override should do the trick. it is on every page of the ap...
Community Member
this feature works, thank you
191
