11-03-2006 02:59 AM - edited 07-03-2021 01:11 PM
Hi forum,
Can wireless clients roam seamlessly between 802.11a and 802.11g APs? they will be using the same SSID.
besides, if I select different channel for bluetooth clients, can it coexist with 802.11g?
Thank you,
paul
11-09-2006 07:44 AM
It is possible for a wireless client to roam between 802.11a and 802.11g.
Try this link:
http://www.cisco.com/warp/public/cc/pd/witc/ao1200ap/prodlit/index.shtml
11-09-2006 04:01 PM
Thank you. Thomas. will go through that.
11-09-2006 05:59 PM
Hi Thomas,
I can't seem to be able to connect documents within the links. Do you have specific documents on this?
