Roaming between 802.11a & g
Hi forum,
Can wireless clients roam seamlessly between 802.11a and 802.11g APs? they will be using the same SSID.
besides, if I select different channel for bluetooth clients, can it coexist with 802.11g?
Thank you,
paul
Silver
Re: Roaming between 802.11a & g
It is possible for a wireless client to roam between 802.11a and 802.11g.
Try this link:
http://www.cisco.com/warp/public/cc/pd/witc/ao1200ap/prodlit/index.shtml
Thank you. Thomas. will go through that.
Hi Thomas,
I can't seem to be able to connect documents within the links. Do you have specific documents on this?
132
