Roaming causing ReauthC on anchored controller
Ben Meagher
Any and all help is appreciated..
So I am seeing an issue where guest clients on an open L3 passthrough anchored wlan are having to reauth upon every roam. (intractroller)  I scoured documentation today and found verbage of several variations of this situation, just not this exactly. I do not have mac filter failure enabled and the below logs are from Prime via the foreign.
2013-Jul-25, 10:16:21 EST
INFO
172.27.26.9
Controller association request message received.
INFO
172.27.26.9
Mobility role update request. from Export Foreign to Local Peer   = 172.21.21.8, Old Anchor = 172.21.21.8, New Anchor = 172.27.26.9
INFO
172.27.26.9
Received reassociation request from client.
INFO
172.27.26.9
Client moved to associated state successfully.
INFO
172.27.26.9
Mobility role update request. from Export Foreign to Export   Foreign Peer = 172.21.21.8, Old Anchor = 172.21.21.8, New Anchor =   172.21.21.8
INFO
172.27.26.9
Mobility role changed. State Update from Mobility-Incomplete to   Mobility-Complete, mobility role=ExpForeign, client   state=APF_MS_STATE_ASSOCIATED
2013-Jul-25, 10:17:24 EST
INFO
172.27.26.9
INFO
172.27.26.9
INFO
172.27.26.9
INFO
172.27.26.9
INFO
172.27.26.9
INFO
172.27.26.9
10 Replies 10
Scott Fella
You have multiple anchors?
-Scott
We did, but currently only anchored off the wlan to one of them. The other anchor that used to also be used is still probably a mobility member from another group in an up/up state, but not referenced here.
I see .8 and .9 for the roaming.
-Scott
The .9 is actually the ip of the foreign that my APs home to, the other anchor is a .10.
Post your show WLAN on both WLC's.
-Scott
Attached...
Show Wlan
I need to see both controllers... you just have one.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Attached is the anchor show wlan < >
I will also mention that the foreign is a WiSM2 running 7.4.100.0
and the anchor is a 4400 running 7.0.240.0
That is fine that your WiSM is running v7.4 and the 4400 is running v7.0.... thats not an issue.
I would change the session timout on the WiSM2 to Infinity and make sure the idle timer on the anchor is set to 14400.
See if that helps.
Scott
-Scott
Aaron Box
Did you solve this issue? I am having a very similar issue.
