Community Member
Routing Issue with Aironet 340 AP
I have a routing problem but I just can't figure out where.
I have 2 nics that are associated to AP #1 which is setup as a repeater. AP #1 talks to AP #2 which acts as the Access Point to my wired LAN. I can ping the IP address of my server from both nics. However, I cannot ping my default gateway. Am I doing something stupid that is routing me incorrectly to my gateway.
Thanks for the help
Community Member
Re: Routing Issue with Aironet 340 AP
You say you can ping your server that means the RF network is working OK. But, you might check to see if there is any MAC filtering configured. That could be the problem.
If not and because Access Points are Data Link devices ( level 2 ), I imagine that if you cannot ping your default gateway you must have some faulty IP configuration either on your nics or network ( wrong subnets or subnet-masks ).
