SATO GL408 Label Printers WLC 4402 6.0.188
Our end customer has many SATO GL408 Label Printers.   Periodically the printers need to be powered down to load some labels.  The majority of the time, these printers can associate with the wireless network no problem.  But, once in a while when the printer comes back online, it is not pingable.  There is no way to ping from the client to test if it is one way since these are static devices. All devices have static IP addresses.
When the above mentioned state occurs, we will see "8021X_REQD" for the Policy Manager State, listed under Client Properties.  The clients are configured for WPA/TKIP.  A reboot of the associated AP (1242AG) will allow packets to flow again.
Has anyone else experienced this behavior?  Is this a known bug?
Client Properties are listed below.  Thank you in advance for your help.
(Cisco Controller) >show client detail 00:08:96:38:01:0c
Client MAC Address............................... 00:08:96:38:01:0c
Client Username ................................. N/A
AP MAC Address................................... 00:23:34:3f:7a:e0
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 4
BSSID............................................ 00:23:34:3f:7a:e3
Connected For ................................... 9 secs
Channel.......................................... 11
IP Address....................................... X.X.X.X
Association Id................................... 63
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Session Timeout.................................. 0
Client CCX version............................... No CCX support
Mirroring........................................ Disabled
QoS Level........................................ Gold
Diff Serv Code Point (DSCP)...................... disabled
802.1P Priority Tag.............................. disabled
WMM Support...................................... Disabled
Power Save....................................... OFF
Current Rate..................................... 54.0
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,
    ............................................. 12.0,18.0,24.0,36.0,48.0,
    ............................................. 54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ No
Policy Manager State............................. 8021X_REQD
Policy Manager Rule Created...................... Yes
ACL Name......................................... none
ACL Applied Status............................... Unavailable
NPU Fast Fast Notified........................... No
Policy Type...................................... WPA1
Authentication Key Management.................... PSK
Encryption Cipher................................ TKIP-MIC
Management Frame Protection...................... No
EAP Type......................................... Unknown
Interface........................................ manufacturing
VLAN............................................. 202
Quarantine VLAN.................................. 0
Access VLAN...................................... 202
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 20
      Fast BSS Transition........................ Not implemented
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 243021
      Number of Bytes Sent....................... 183997
      Number of Packets Received................. 2439
      Number of Packets Sent..................... 1351
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Key Msg Timeouts............. 4
      Number of Data Retries..................... 9
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 0
      Number of Decrypt Failed Packets........... 672
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ -54 dBm
      Signal to Noise Ratio...................... 45 dB
Nearby AP Statistics:
      HMI-AP-05(slot 0) .........................
antenna0: 10 seconds ago -77 dBm................. antenna1: 4294851290 seconds ago -128 dBm
      HMI-AP-04(slot 0) .........................
antenna0: 10 seconds ago -55 dBm................. antenna1: 4294851290 seconds ago -128 dBm
      HMI-AP-03(slot 0) .........................
antenna0: 10 seconds ago -66 dBm................. antenna1: 4294851290 seconds ago -128 dBm
      HMI-AP-02(slot 0) .........................
antenna0: 10 seconds ago -85 dBm................. antenna1: 4294851290 seconds ago -128 dBm
      HMI-AP-01(slot 0) .........................
antenna0: 10 seconds ago -67 dBm................. antenna1: 4294851290 seconds ago -128 dBm
Re: SATO GL408 Label Printers WLC 4402 6.0.188
Are you doing 802.1x on these devices?
Hall of Fame Super Gold
I'd check your RADIUS/TACACS server.  Reason Code of "1" means "Go Away".
RADIUS is not used on the WLAN in which these clients are associated.  They authenticate via Pre-shared Key (WPA/TKIP).
The odd behavior is when the WAP is rebooted, the client can then communicate with the network.
1168
