secure VPN connection terminated by local host/remote vpn peer is no longer responding
I am trying to configure the Router 2911 for Cisco VPN client access for the remote hosts. LAN-switch-router is how my network is set up.
I have used all that is been said on cisco website. but still not able to connect to it by creating the pcf file. It gives me error saying : secure VPN connection terminated by local host/ remote vpn peer is no longer responding.
Not sure if I am missing some configs or I configured something wrong.
belwo is my config:
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_10 local
aaa authorization console
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_10 local
aaa session-id common
no ipv6 cef
ipv6 spd queue min-threshold 62
ipv6 spd queue max-threshold 63
ip source-route
ip cef
ip domain name xyz.LOCAL
ip inspect log drop-pkt
parameter-map type inspect global
 log dropped-packets enable
archive
 log config
  logging enable
  hidekeys
username test password 7 105A0C0A11
redundancy
ip ssh version 2
class-map type inspect match-any MGMT
 match protocol ssh
 match protocol snmp
class-map type inspect match-any ICMP
 match protocol icmp
class-map type inspect match-all IPSEC-VPN
 match access-group name IPSEC-VPN
class-map type inspect match-any TCP-UDP
 match protocol tcp
 match protocol udp
class-map type inspect match-all STATIC-NAT
 match access-group name STATIC-NAT
policy-map type inspect INSIDE->SELF
 class type inspect ICMP
  pass
 class type inspect MGMT
  pass
 class class-default
  drop
policy-map type inspect INSIDE->OUTSIDE
 class type inspect TCP-UDP
  inspect
  inspect
 class class-default
  drop
policy-map type inspect OUTSIDE->SELF
  pass
 class type inspect IPSEC-VPN
  pass
 class class-default
  drop
policy-map type inspect OUTSIDE->INSIDE
 class type inspect STATIC-NAT
  inspect
 class class-default
  drop
zone security INSIDE
zone security OUTSIDE
zone-pair security INSIDE->OUTSIDE-ZP source INSIDE destination OUTSIDE
 service-policy type inspect INSIDE->OUTSIDE
zone-pair security INSIDE->SELF-ZP source INSIDE destination self
 service-policy type inspect INSIDE->SELF
zone-pair security OUTSIDE->SELF-ZP source OUTSIDE destination self
 service-policy type inspect OUTSIDE->SELF
zone-pair security OUTSIDE->INSIDE-ZP source OUTSIDE destination INSIDE
 service-policy type inspect OUTSIDE->INSIDE
crypto isakmp policy 5
 encr 3des
 authentication pre-share
 group 2
!--- Create an Internet Security Association and
!--- Key Management Protocol (ISAKMP) policy for Phase 1 negotiations.
crypto isakmp policy 55
 encr aes 256
 group 2
crypto isakmp client configuration group internal
 key key_internal
 dns 10.10.37.33 10.10.37.30
 pool REMOTE_ACCESS_POOL
 save-password
 max-users 10
 netmask 255.255.255.0
crypto isakmp profile Current-ike-profile-1
   match identity group internal
   client authentication list sdm_vpn_xauth_ml_10
   isakmp authorization list sdm_vpn_group_ml_10
   client configuration address respond
   virtual-template 13
crypto ipsec transform-set EASY esp-aes 256 esp-sha-hmac
crypto ipsec profile Current
 set transform-set EASY
 set reverse-route tag 10
 set isakmp-profile Current-ike-profile-1
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 1.1.1.2 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 zone-member security OUTSIDE
 load-interval 30
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 10.10.64.1 255.255.255.248
 ip nat inside
 zone-member security INSIDE
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
interface Virtual-Template13 type tunnel
 ip unnumbered GigabitEthernet0/0
 ip nat inside
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile Current
ip local pool REMOTE_ACCESS_POOL 10.10.44.2 10.10.44.254
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 10.10.0.0 255.255.0.0 10.10.64.2
ip access-list extended IPSEC-VPN
 permit esp any any
 permit udp any any eq isakmp
 permit udp any any eq non500-isakmp
ip access-list extended NAT
 permit ip 10.10.44.0 0.0.0.255 any
ip access-list extended STATIC-NAT
 permit ip any 10.10.37.0 0.0.0.255
snmp-server community ROUTER RO
snmp-server enable traps config
snmp-server host 10.10.37.37 version 2c RO
control-plane
line con 0
 logging synchronous
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 logging synchronous
 transport input ssh
 transport output ssh
line vty 5 15
 logging synchronous
 transport input ssh
scheduler allocate 20000 1000
end
505
