Setting up Multiple SSID's & VLAN
I have a Cisco 1230 AP along with a Sonic Wall TZ 210 and a Linksys SFE 2010P switch. On my AP I have created 2 SSID's. and 2 VLAN's. The first SSID is being broadcasted and has WPA encryption on it for our Corporate USers. The Second SSID is a Guest SSID and too is being broadcasted. I can make a laptop connect to the 1st SSID, but for some reason the 2nd SSID nothing will connect to it.  The first SSID is associated to VLAN1 and the 2nd SSID is associated to VLAN2. VLAN1 has WPA encryption on it. VLAN2 is setup as Open and no Encryption. Any ideas?
My next question is how to I configure traffic on this AP with the other equipment mentioned? On my sonicwall we have segmented port6 on it to be a different subnet from the corporate subnet. On the Linksys switch I have enable VLANS on port2 and port48 which are on VLAN2. All other ports are on VLAN1. The AP connects to Ports 2 on the linksys switch and port 48 connects to port 6 on the Sonic Wall. When a corporate user connects to SSID1 I want them to be able to connect to the Corporate subnet. When a guest connects to SSID2 I want them to connect to the segmented guest network to only have Internet Access.
Hope this makes sense!
Below is my config on the AP. I am really only familiar with the IOS web interface so if you can explain it using that I'd appreciate it.
AP_WLAN_Bakery
Home     Exec     Configure
------------------ show version ------------------ Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JEB1, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2007 by Cisco Systems, Inc. Compiled Fri 20-Jul-07 20:51 by dchih ROM: Bootstrap program is C1200 boot loader BOOTLDR: C1200 Boot Loader (C1200-BOOT-M) Version 12.2(8)JA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) AP_WLAN_Bakery uptime is 1 hour, 40 minutes System returned to ROM by reload System restarted at 10:52:05 -0400 Fri Oct 15 2010 System image file is "flash:/c1200-k9w7-mx.123-8.JEB1/c1200-k9w7-mx.123-8.JEB1" This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco AIR-AP1231G-A-K9     (PowerPC405GP) processor (revision B0) with 15138K/1236K bytes of memory. Processor board ID FOC0849218B PowerPC405GP CPU at 196Mhz, revision number 0x0145 Last reset from reload 1 FastEthernet interface 1 802.11 Radio(s) 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: 00:12:D9:8B:09:93 Part Number                          : 73-8704-08 PCA Assembly Number                  : 800-23211-09 PCA Revision Number                  : A0 PCB Serial Number                    : FOC0849218B Top Assembly Part Number             : 800-23304-08 Top Assembly Serial Number           : FTX0902R2V1 Top Revision Number                  : A0 Product/Model Number                 : AIR-AP1231G-A-K9    Configuration register is 0xF ------------------ show running-config ------------------ Building configuration... Current configuration : 2544 bytes ! ! Last configuration change at 12:07:29 -0400 Fri Oct 15 2010 by admin ! NVRAM config last updated at 12:07:29 -0400 Fri Oct 15 2010 by admin ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname AP_WLAN_Bakery ! ! clock timezone -0500 -5 clock summer-time -0400 recurring ip subnet-zero ! ! aaa new-model ! ! aaa authentication login default local aaa authorization exec default local aaa session-id common dot11 vlan-name VLAN_Corporate vlan 1 dot11 vlan-name VLAN_Guest vlan 2 ! dot11 ssid WLAN_Corporate    vlan 1    authentication open    authentication key-management wpa    mbssid guest-mode    wpa-psk ascii 7 005740565C0C5C5F5C741F ! dot11 ssid WLAN_HartKitGuest    vlan 2    authentication open    mbssid guest-mode ! ! ! username admin privilege 15 password 7 <removed> ! bridge irb ! ! interface Dot11Radio0 no ip address no ip route-cache ! encryption mode ciphers aes-ccm tkip ! encryption vlan 1 mode ciphers aes-ccm tkip ! ssid WLAN_Corporate ! ssid WLAN_HartKitGuest ! mbssid speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 station-role root no dot11 extension aironet ! interface Dot11Radio0.1 encapsulation dot1Q 1 native no ip route-cache bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding bridge-group 1 spanning-disabled ! interface Dot11Radio0.2 encapsulation dot1Q 2 no ip route-cache bridge-group 2 bridge-group 2 subscriber-loop-control bridge-group 2 block-unknown-source no bridge-group 2 source-learning no bridge-group 2 unicast-flooding bridge-group 2 spanning-disabled ! interface FastEthernet0 no ip address no ip route-cache duplex auto speed auto ! interface FastEthernet0.1 encapsulation dot1Q 1 native no ip route-cache bridge-group 1 no bridge-group 1 source-learning bridge-group 1 spanning-disabled ! interface FastEthernet0.2 encapsulation dot1Q 2 no ip route-cache bridge-group 2 no bridge-group 2 source-learning bridge-group 2 spanning-disabled ! interface BVI1 ip address 192.168.2.240 255.255.255.0 no ip route-cache ! ip default-gateway 192.168.2.1 ip http server ip http authentication aaa no ip http secure-server ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag ! bridge 1 route ip ! ! ! line con 0 line vty 0 4 ! sntp server 192.168.2.5 sntp broadcast client end ------------------ show stacks ------------------ Minimum process stacks: Free/Size   Name 4572/5500   soap_flash init 10024/11000  DHCP Autoinstall 5160/5500   Autoinstall 11748/12000  Setup 10552/11000  BootP Resolver 5240/5500   dot11 platform init 8824/12000  Init 5088/5500   RADIUS INITCONFIG 2576/3000   Rom Random Update Process 5144/11000  HTTP CP 3084/5500   Soap Flash Save Variables Interrupt level stacks: Level    Called Unused/Size  Name   4      125707   8056/9000  dot11 radio interrupt   6        9783   8960/9000  NS16550 VECTOR ------------------ show interfaces ------------------ BVI1 is up, line protocol is up   Hardware is BVI, address is 0012.d98b.0993 (bia 0013.1973.8d50)   Internet address is 192.168.2.240/24   MTU 1500 bytes, BW 54000 Kbit, DLY 5000 usec,      reliability 255/255, txload 1/255, rxload 1/255   Encapsulation ARPA, loopback not set   ARP type: ARPA, ARP Timeout 04:00:00   Last input never, output never, output hang never   Last clearing of "show interface" counters never   Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0   5 minute input rate 10000 bits/sec, 9 packets/sec   5 minute output rate 10000 bits/sec, 4 packets/sec      59436 packets input, 8310033 bytes, 0 no buffer      Received 0 broadcasts, 0 runts, 0 giants, 0 throttles      0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort      31826 packets output, 18823451 bytes, 0 underruns      0 output errors, 0 collisions, 0 interface resets      0 output buffer failures, 0 output buffers swapped out Dot11Radio0 is up, line protocol is up   Hardware is 802.11G Radio, address is 0013.1973.8d50 (bia 0013.1973.8d50)   MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,      reliability 255/255, txload 1/255, rxload 1/255   Encapsulation ARPA, loopback not set   ARP type: ARPA, ARP Timeout 04:00:00   Last input 00:15:20, output 00:15:20, output hang never   Last clearing of "show interface" counters never   Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 47   Queueing strategy: fifo   Output queue: 0/30 (size/max)   5 minute input rate 0 bits/sec, 0 packets/sec   5 minute output rate 0 bits/sec, 0 packets/sec      16093 packets input, 1696312 bytes, 0 no buffer      Received 1913 broadcasts, 0 runts, 0 giants, 0 throttles      0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored      0 input packets with dribble condition detected      8367 packets output, 2930004 bytes, 0 underruns      13 output errors, 0 collisions, 37 interface resets      0 babbles, 0 late collision, 0 deferred      0 lost carrier, 0 no carrier      0 output buffer failures, 0 output buffers swapped out Dot11Radio0.1 is up, line protocol is up   Hardware is 802.11G Radio, address is 0013.1973.8d50 (bia 0013.1973.8d50)   MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,      reliability 255/255, txload 1/255, rxload 1/255   Encapsulation 802.1Q Virtual LAN, Vlan ID  1.   ARP type: ARPA, ARP Timeout 04:00:00   Last clearing of "show interface" counters never Dot11Radio0.2 is up, line protocol is up   Hardware is 802.11G Radio, address is 0013.1973.8d50 (bia 0013.1973.8d50)   MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,      reliability 255/255, txload 1/255, rxload 1/255   Encapsulation 802.1Q Virtual LAN, Vlan ID  2.   ARP type: ARPA, ARP Timeout 04:00:00   Last clearing of "show interface" counters never FastEthernet0 is up, line protocol is up   Hardware is PowerPC405GP Ethernet, address is 0012.d98b.0993 (bia 0012.d98b.0993)   MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,      reliability 255/255, txload 1/255, rxload 1/255   Encapsulation ARPA, loopback not set   Full-duplex, 100Mb/s, MII   ARP type: ARPA, ARP Timeout 04:00:00   Last input 00:00:00, output 00:00:00, output hang never   Last clearing of "show interface" counters never   Input queue: 0/160/0/0 (size/max/drops/flushes); Total output drops: 0   Queueing strategy: fifo   Output queue: 0/40 (size/max)   5 minute input rate 13000 bits/sec, 10 packets/sec   5 minute output rate 10000 bits/sec, 4 packets/sec      75878 packets input, 12726627 bytes      Received 43517 broadcasts, 0 runts, 0 giants, 0 throttles      0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored      0 watchdog      0 input packets with dribble condition detected      38986 packets output, 19917202 bytes, 0 underruns      0 output errors, 0 collisions, 7 interface resets      0 babbles, 0 late collision, 0 deferred      0 lost carrier, 0 no carrier      0 output buffer failures, 0 output buffers swapped out FastEthernet0.1 is up, line protocol is up   Hardware is PowerPC405GP Ethernet, address is 0012.d98b.0993 (bia 0012.d98b.0993)   MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,      reliability 255/255, txload 1/255, rxload 1/255   Encapsulation 802.1Q Virtual LAN, Vlan ID  1.   ARP type: ARPA, ARP Timeout 04:00:00   Last clearing of "show interface" counters never FastEthernet0.2 is up, line protocol is up   Hardware is PowerPC405GP Ethernet, address is 0012.d98b.0993 (bia 0012.d98b.0993)   MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,      reliability 255/255, txload 1/255, rxload 1/255   Encapsulation 802.1Q Virtual LAN, Vlan ID  2.   ARP type: ARPA, ARP Timeout 04:00:00   Last clearing of "show interface" counters never ------------------ show controllers ------------------ ! interface Dot11Radio0 Radio AIR-MP31G, Base Address 0013.1973.8d50, BBlock version 0.00, Software version 6.11.1 Serial number: FOC0901D4S1 Number of supported simultaneous BSSID on Dot11Radio0: 8 Carrier Set: Americas (US ) Uniform Spreading Required: No Current Frequency: 2412 MHz  Channel 1 Allowed Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447(8) 2452(9) 2457(10) 2462(11) Listen Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13) 2484(14) Beacon Flags: 0; Beacons are enabled; Probes are enabled Current CCK Power: 100 mW Allowed CCK Power Levels: 1 5 10 20 30 50 100 Current OFDM Power: 30 mW Allowed OFDM Power Levels: 1 5 10 20 30 Allowed Client Power Levels: 1 5 10 20 30 50 100 ERP settings: short slot time. Neighbors in non-erp mode: Current Rates:  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 Active Rates:  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 Allowed Rates:  1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0 Best Range Rates:  basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0 Best Throughput Rates:  basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 Default Rates:  basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0 Current Voice Rates:  5.5 6.0 11.0 12.0 24.0 [disabled until voice packet-discard enabled] Default Voice Rates:  5.5 6.0 11.0 12.0 24.0 Channel / Max Power Table   1 O=15 D=20,    2 O=15 D=20,    3 O=15 D=20,    4 O=15 D=20,    5 O=15 D=20   6 O=15 D=20,    7 O=15 D=20,    8 O=15 D=20,    9 O=15 D=20,   10 O=15 D=20 11 O=15 D=20 Data Rate Sensitivity (rate, SNR dB, Contention dBm) ( 1.0,  1, -98)   ( 2.0,  7, -94)   ( 5.5,  9, -92)   (11.0, 16, -86)   ( 6.0,  7, -92)   ( 9.0, 14, -87)   (12.0, 12, -87)   (18.0, 15, -84)   (24.0, 17, -82)   (36.0, 24, -76)   (48.0, 29, -73)   (54.0, 33, -69)   Radio Management (RM) Configuration: Regular AP RM Mode 1   Temp Setting Disabled Temp  Settings: AP Tx Power 0    AP Tx Channel 0    Client Tx Power 0        Rates: Saved Settings: AP Tx Power 0    AP Tx Channel 1    Client Tx Power 0        Rates: MCST RSCs: [0]0x0 [1]0x0 [2]0x0 [3]0x0 [4]0x0 TKIP Cum Stats: STA            MIC-L-Errs MIC-R-Errs Replay   C-Measure                 0000.0000.0000 00000000   00000000   00000000 00000000 AES-CCMP Cum Stats: 00000000 replays discarded QBSS Load: 0x0 Policing Stats:Rx downgardes 0, Tx downgrades 0 Configured Local Access Class Parameters   Back      : cw-min 4 cw-max 10 fixed-slot 7 admission-control Off txop 0   Best      : cw-min 4 cw-max 6 fixed-slot 3 admission-control Off txop 0   Video     : cw-min 3 cw-max 4 fixed-slot 1 admission-control Off txop 3008   Voice     : cw-min 2 cw-max 3 fixed-slot 1 admission-control Off txop 1504 Configured Cell Access Class Parameters   Back      : cw-min 4 cw-max 10 fixed-slot 7 admission-control Off txop 0   Best      : cw-min 4 cw-max 10 fixed-slot 3 admission-control Off txop 0   Video     : cw-min 3 cw-max 4 fixed-slot 2 admission-control Off txop 3008   Voice     : cw-min 2 cw-max 3 fixed-slot 2 admission-control Off txop 1504 Transmit queues: Active 0 In Progress 0        ---- Active --- In-Progress --------------- Counts --------------        Cnt Quo Bas Max Cnt Quo Bas       Sent   Discard  Fail   Retry Multi Uplink   0   0   0   0   0   0   0          0         0     0       0     0 Voice    0   0   0   0   0   0   0         55         0     0       1     1 Video    0   0   0   0   0   0   0          0         0     0       0     0 Best     0   3  70   3   0   3  24       7937         0     0     127    12 Mcast    0   0   0   0   0   0   0        329         0     0       0     0 Mcast    0   0   0   0   0   0   0         30         0     0       0     0 Back     0   0   0   0   0   0   0        329         0     0       0     0 BSSIDS Index Flags State Next Held Defer NonDefer Clients Tsf Dtim Txq   8D50     0    20     0    0    0     0        0       0 200    2   0   8D51     1    20     0    0    0     0        0       0 150    2   1 UP ClientQAged    AcQAged PacketAged Drop  Retry/Thresh Timeout CQMax 7           0          0          0       3/100  0/500      35     4 6           0          0          0       3/100  0/500      35     4 5           0          0          0       3/100  0/500      35     4 4           0          0          0       3/100  0/500      35     4 3           0          0          0       3/100  0/500      35     4 2           0          0          0       3/100  0/500      35     4 1           0          0          0       3/100  0/500      35     4 Driver TX blocks: in use 0, high 10, at reset 0, fail 0, reclaim 0 Clients: 8021x auth in prog 0 allowed 0 Vlan BSSID   Clients PSP Pri Encr  Key0 Key1 Key2 Key3 SSIDs    0  8D50 0       0   0   0  234       x128             1n 8D50 0       0   0   0  234       x128           WLAN_Corporate    2  8D51 1       0   0   0    0                      WLAN_HartKitGuest 0 0 flags 3 1 1 flags 3 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 0 0 flags 0 17 0 flags 0 18 0 flags 0 Registers: io E8000000 mem 80000000 aux A0000000 0000 FF50 0000 0000 0021 0000 0000 0000 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0500 0007 0000 0000 0808 09E8 0000 0504 0000 0000 0000 0000 0424 0059 E2ED 2D9D 00000000 00000200 20000200 FFFFFFFF F7FFFFFF 00000000 00000000 00200000 FFFFFFE2 00000FFF 72ED14BD 4A040401 00000000 00000000 00008000 00008080 00000000 00000000 00000000 00000000 00008F78 000012DC 00000000 0000C0EA Radio running:  temp 0 C tx_power 100 bb_code 0x0     rssi_threshold 0x0 gain offset 0 Antenna: external , gain 20 (platform 0, domain class A) PCI sys_id: 0xA506 subsys_id 0x5100 (0x5101) Unicast ciphers 0x1 mcast ciphers 0x1 Rid Ring: A0000970: 009C8000 20ED1EA0 * n Rx Ring: A0000950: 893E0002 20ED3478   v, 893E0002 20EDEE60   v A0000960: 893E0002 20EE4B54   v, 893E0002 20EDB068 * v Tx Ring: A0000800: 06108000 20ECFCE4   n, 009A8000 20ECD764   n A0000810: 00AE8000 20ECF064   n, 010C8000 20ECD124   n A0000820: 010C8000 20ECCE04   n, 010C8000 20ECE0C4   n A0000830: 010C8000 20ECED44   n, 00668000 20ECB174   n A0000840: 006A8000 20ECCA64   n, 010C8000 20ECDDA4   n A0000850: 010C8000 20ECF6A4   n, 01848000 20ECF9C4   n A0000860: 022A8000 20ECCE04   n, 01848000 20ECF9C4   n A0000870: 06158000 20ED113C   n, 01848000 20ECE3E4   n A0000880: 022A8000 20ECF064 * n, 01188000 20ECD124   n A0000890: 05688000 20ED0A74   n, 057C8000 20ED03AC   n A00008A0: 010C8000 20ECED44   n, 010C8000 20ECDDA4   n A00008B0: 010C8000 20ECF6A4   n, 010C8000 20ECF9C4   n A00008C0: 00748000 20ECB054   n, 05FC8000 20ED1804   n TxDn Ring: A0000930: 802C0000 20ED26A0   v, 802C0000 20ED2778   v A0000940: 802C0000 20ED2850 * v, 802C0000 20ED2928   v Multicast counters: Internal MC counts: 28 (28) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) Log Buffer: PowerPC405GP Ethernet unit 0 PHY Hardware is Intel LXT971 rev. 2 (id_register: 0x13, 0x78E2) rx_intr: 0 tx_intr: 0 mac_err_isr: 0 phy_link_isr:0 Current station address 0012.d98b.0993, default address 0012.d98b.0993 MAL register dump: malcr        0x0007C082  0x180 malesr       0x00000000  0x181 malier       0x0000000F  0x182 maltxcasr    0x80000000  0x184 maltxcarr    0x80000000  0x185 maltxeobisr  0x00000000  0x186 maltxdeir    0x00000000  0x187 malrxcasr    0x80000000  0x190 malrxcarr    0x80000000  0x191 malrxeobisr  0x00000000  0x192 malrxdeir    0x00000000  0x193 maltxctp0r   0x00EE6120  0x1A0 malrxctp0r   0x00EE6020  0x1C0 malrcbs0   0x00000060  0x1E0 EMAC register dump: emacmr0      0x18000000  0x00 emacmr1      0xA1788000  0x04 emactmr0     0x00000000  0x08 emactmr1     0x380F0000  0x0C emacrmr      0x7D180000  0x10 emacisr      0x00000002  0x14 emacier      0x00000001  0x18 emaciah      0x00000012  0x1C emacial      0xD98B0993  0x20 emacptr      0x0000FFFF  0x2C emaclsah     0x00000040  0x50 emaclsal     0x2B637E9B  0x54 emacipgr     0x00000004  0x58 emacstacr    0x47808011  0x5C emactrtr     0x18000000  0x60 emacrwmr     0x0F002000  0x64 emacoctx     0x0132EA47  0x68 emacocrx     0x00C72D8B  0x6C UIC register dump: uicsr      0x00001FA3  0xC0 uicer      0x803F0048  0xC2 uicmsr     0x00000000  0xC6 PHY register dump: 3100 782D 0013 78E2 01E1 41E1 0007 2001 0000 0000 0000 0000 0000 0000 0000 0000 0384 4780 0032 0000 0422 0000 0000 0000 0000 0000 08C8 0000 0000 0000 0000 RX ring with 16 entries at 0xEE6020, Buffer size 1528 Rxhead = 0xEE6048 (5), Rxp = 0xB67360 (5) 00 pak=0x0B6D644 buf=0x0EF2BDC status=9C00 pak_size=0 01 pak=0x0B6CCA8 buf=0x0EF17A8 status=9C00 pak_size=0 02 pak=0x0B68C98 buf=0x0EE90F8 status=9C00 pak_size=0 03 pak=0x0B6BCA4 buf=0x0EEF5FC status=9C00 pak_size=0 04 pak=0x0B6DFE0 buf=0x0EF4010 status=9C00 pak_size=0 05 pak=0x0B6CFDC buf=0x0EF1E64 status=9C00 pak_size=0 06 pak=0x0B6C640 buf=0x0EF0A30 status=9C00 pak_size=0 07 pak=0x0B682FC buf=0x0EE7CC4 status=9C00 pak_size=0 08 pak=0x0B6E648 buf=0x0EF4D88 status=9C00 pak_size=0 09 pak=0x0B6E97C buf=0x0EF5444 status=9C00 pak_size=0 10 pak=0x0B6ECB0 buf=0x0EF5B00 status=9C00 pak_size=0 11 pak=0x0B6ACA0 buf=0x0EED450 status=9C00 pak_size=0 12 pak=0x0B68630 buf=0x0EE8380 status=9C00 pak_size=0 13 pak=0x0B6D310 buf=0x0EF2520 status=9C00 pak_size=0 14 pak=0x0B6C974 buf=0x0EF10EC status=9C00 pak_size=0 15 pak=0x0B6B63C buf=0x0EEE884 status=DC00 pak_size=0 TX ring with 8 entries at 0xEE6120, tx_count = 0 tx_head = 0xEE6148 (5), head_txp = 0xB673BC (5) tx_tail = 0xEE6148 (5), tail_txp = 0xB673BC (5) 00 pak=0x0000000 buf=0x0000000 status=1400 pak_size=0 01 pak=0x0000000 buf=0x0000000 status=1400 pak_size=0 02 pak=0x0000000 buf=0x0000000 status=1400 pak_size=0 03 pak=0x0000000 buf=0x0000000 status=1400 pak_size=0 04 pak=0x0000000 buf=0x0000000 status=1400 pak_size=0 05 pak=0x0000000 buf=0x0000000 status=1400 pak_size=0 06 pak=0x0000000 buf=0x0000000 status=1400 pak_size=0 07 pak=0x0000000 buf=0x0000000 status=5400 pak_size=0 0 missed datagrams, 0 overruns 0 transmitter underruns, 0 excessive collisions 0 single collisions, 0 multiple collisions 0 dma memory errors, 0 CRC errors 0 alignment errors, 0 runts, 0 giants emac/mal specific errors: 0 rx in range, 0 rx out range 0 mal_rx_serr, 0 mal_tx_serr 0 mal_rx_de, 0 mal_tx_de 0 emac_int 0 mal_err_isr 0 SQE errors, 0 tx CRC errors 0 output queue fail ------------------ show data-corruption ------------------ No data inconsistency errors have been recorded. ------------------ show file systems ------------------ File Systems:      Size(b)     Free(b)      Type  Flags  Prefixes *    7741440     2734080     flash     rw   flash:            -           -    opaque     rw   bs:      7741440     2734080   unknown     rw   zflash:            -           -    opaque     rw   archive:            -           -    opaque     rw   system:        32768       29138     nvram     rw   nvram:            -           -   network     rw   tftp:            -           -    opaque     rw   null:            -           -    opaque     ro   xmodem:            -           -    opaque     ro   ymodem:            -           -   network     rw   rcp:            -           -   network     rw   ftp:            -           -   network     rw   http:            -           -   network     rw   scp:            -           -   network     rw   https: ------------------ show flash: ------------------ Directory of flash:/     2  -rwx        1048  Oct 15 2010 12:07:29 -04:00  private-multiple-fs     5  drwx         512  Oct 15 2010 10:36:30 -04:00  c1200-k9w7-mx.123-8.JEB1     4  -rwx         716  Feb 28 2002 19:06:22 -05:00  env_vars   146  -rwx        2549  Oct 15 2010 12:07:29 -04:00  config.txt   148  -rwx           5  Oct 15 2010 12:07:29 -04:00  private-config 7741440 bytes total (2734080 bytes free) ------------------ dir nvram: ------------------ Directory of nvram:/    30  -rw-        2549                    <no date>  startup-config    31  ----           5                    <no date>  private-config     1  -rw-           0                    <no date>  ifIndex-table 32768 bytes total (29138 bytes free) ------------------ show memory statistics ------------------                 Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b) Processor     A4AB84     4709500     2431436     2278064     1920552     2125904       I/O     ECB000     1265664      468008      797656      727168      779580 ------------------ show process memory ------------------ Total: 5975164, Used: 2899444, Free: 3075720 PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process    0   0    3373064     827724    1898920          0          0 *Init*             0   0      11804    7372856      11804          0          0 *Sched*            0   0   66125428   65999528     293168     434276          0 *Dead*             1   0          0          0       6416          0          0 Chunk Manager      2   0        188        188       3916          0          0 Load Meter         3   0     448120     443220      18392          0          0 HTTP CP            4   0      19548          0      25964          0          0 Check heaps        5   0      86364     207192      37368      49920     137052 Pool Manager       6   0          0          0       6416          0          0 AAA_SERVER_DEADT    7   0        188        188       6416          0          0 Timers             8   0        188        188       6416          0          0 AAA high-capacit    9   0        488          0       6904          0          0 SNTP              10   0         76          0       6492          0          0 ARP Input         11   0       3232        540       9108          0          0 Entity MIB API    12   0          0          0       6416          0          0 HC Counter Timer   13   0        188        188       6416          0          0 GraphIt           14   0          0          0       6416          0          0 Net Input         15   0          0          0       6416          0          0 Critical Bkgnd    16   0      19648        136      12180          0          0 Net Background    17   0        188        188      11916          0          0 Logger            18   0        188        188       6416          0          0 TTY Background    19   0          0          0       9916          0          0 Per-Second Jobs   20   0        188        188       6416          0          0 Compute load avg   21   0          0          0       6416          0          0 Per-minute Jobs   22   0     125880      59144      52956          0          0 Dot11 driver      23   0        188        188       6416          0          0 Dot11 driver log   24   0          0          0       6416          0          0 Voice Metrics Ta   25   0          0          0       6416          0          0 SOAP LED Process   26   0        188        188       6416          0          0 AAA Server        27   0          0          0       6416          0          0 AAA ACCT Proc     28   0          0          0       6416          0          0 ACCT Periodic Pr   29   0    2343100   10891400      16904          0    7173144 IP Input          30   0          0          0       6416          0          0 ICMP event handl   31   0        188        188       6416          0          0 AAA Dictionary R   32   0      47124      44272       9200          0          0 CDP Protocol      33   0          0          0       6416          0          0 linktest          34   0        964        964       9916          0          0 Dot11 aaa proces   35   0          0          0       9916          0          0 pmkid             36   0        188       6404       6416          0          0 Dot11 Mgmt & Ass   37   0       1636       1224       6644          0          0 AiroIAPP Protoco   38   0        188        188       6416          0          0 Triggered events   39   0        188        188       9916          0          0 Dot11 auth Dot1x   40   0          0          0       6416          0          0 Dot11 Mac Auth    41   0       1276          0       7692          0          0 Dot11CACprocess   42   0          0    1285716      11916          0          0 TCP Timer         43   0          0          0      11916          0          0 TCP Protocols     44   0          0          0       6416          0          0 Socket Timers     45   0      41144      11308      23364          0          0 DHCPD Receive     46   0   58666708   40499364      31400    6957504     101520 HTTP CORE         47   0       1072        188      12800          0          0 Soap Upgrade fet   48   0      10608        188      16836          0          0 DDP               49   0     344168    1754412       6416          0          0 LOCAL AAA         50   0        188        188       6416          0          0 AAA Cached Serve   51   0        188        188       6416          0          0 ENABLE AAA        52   0        188        188       6416          0          0 LINE AAA          54   0       2056        188       8284          0          0 TPLUS             55   0        604        188       9332          0          0 Crypto WUI        56   0          0          0       6416          0          0 EM Background Pr   57   0        188        308       6416          0          0 Soap Consoleless   58   0      72384      66968      14332          0          0 Crypto CA         59   0          0          0       8916          0          0 Crypto PKI-CRL    60   0          0          0       8916          0          0 Crypto SSL        61   0       2056      15044       6416          0          0 AAA SEND STOP EV   62   0        188        188       6416          0          0 Dot11 LBS Proc    63   0          0          0       6416          0          0 Syslog Traps      65   0          0          0       6416          0          0 DHCPD Timer       66   0         76        484       9992          0          0 DHCP Client       67   0     636960        188      22156     421308          0 HyBridge Input P   68   0        344        188       6588          0          0 Tbridge Monitor   69   0        344        188       6572          0          0 Spanning Tree     70   0        156          0       6628          0          0 DHCPD Database                                    2897284 Total ------------------ show process cpu ------------------ CPU utilization for five seconds: 16%/0%; one minute: 4%; five minutes: 1% PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process    1           0         1          0  0.00%  0.00%  0.00%   0 Chunk Manager       2           4      1196          3  0.00%  0.00%  0.00%   0 Load Meter          3         369        40       9225  0.00%  0.00%  0.00%   0 HTTP CP             4         764       611       1250  0.00%  0.00%  0.00%   0 Check heaps         5           9        44        204  0.00%  0.00%  0.00%   0 Pool Manager        6           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT    7           0         2          0  0.00%  0.00%  0.00%   0 Timers              8           0         9          0  0.00%  0.00%  0.00%   0 AAA high-capacit    9           8       158         50  0.00%  0.00%  0.00%   0 SNTP               10        1034      5268        196  0.00%  0.02%  0.00%   0 ARP Input          11           2         2       1000  0.00%  0.00%  0.00%   0 Entity MIB API     12           2      1494          1  0.00%  0.00%  0.00%   0 HC Counter Timer   13           2      5973          0  0.00%  0.00%  0.00%   0 GraphIt            14           0        11          0  0.00%  0.00%  0.00%   0 Net Input          15           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd     16          34      1906         17  0.00%  0.00%  0.00%   0 Net Background     17           4       101         39  0.00%  0.00%  0.00%   0 Logger             18          24      5969          4  0.00%  0.00%  0.00%   0 TTY Background     19           5      5998          0  0.00%  0.00%  0.00%   0 Per-Second Jobs    20           0      1196          0  0.00%  0.00%  0.00%   0 Compute load avg   21         433       127       3409  0.00%  0.00%  0.00%   0 Per-minute Jobs    22         587    181376          3  0.00%  0.00%  0.00%   0 Dot11 driver       23           0         2          0  0.00%  0.00%  0.00%   0 Dot11 driver log   24           2      1200          1  0.00%  0.00%  0.00%   0 Voice Metrics Ta   25          44     39944          1  0.00%  0.00%  0.00%   0 SOAP LED Process   26         238      3309         71  0.00%  0.00%  0.00%   0 AAA Server         27           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc      28           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr   29       10607     39208        270  0.31%  0.16%  0.09%   0 IP Input           30           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl   31           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R   32          96       999         96  0.00%  0.00%  0.00%   0 CDP Protocol       33           2      5997          0  0.00%  0.00%  0.00%   0 linktest           34          14       115        121  0.00%  0.00%  0.00%   0 Dot11 aaa proces   35           1       100         10  0.00%  0.00%  0.00%   0 pmkid              36         116      2261         51  0.00%  0.00%  0.00%   0 Dot11 Mgmt & Ass   37          18      7228          2  0.00%  0.00%  0.00%   0 AiroIAPP Protoco   38           0         2          0  0.00%  0.00%  0.00%   0 Triggered events   39           0         2          0  0.00%  0.00%  0.00%   0 Dot11 auth Dot1x   40           0         1          0  0.00%  0.00%  0.00%   0 Dot11 Mac Auth     41           2      1200          1  0.00%  0.00%  0.00%   0 Dot11CACprocess    42          59      2009         29  0.00%  0.00%  0.00%   0 TCP Timer          43           0         1          0  0.00%  0.00%  0.00%   0 TCP Protocols      44           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers      45          14        54        259  0.00%  0.00%  0.00%   0 DHCPD Receive      46       48468     30304       1599  9.35%  1.66%  0.36%   0 HTTP CORE          47           0         2          0  0.00%  0.00%  0.00%   0 Soap Upgrade fet   48           0         2          0  0.00%  0.00%  0.00%   0 DDP                49         707      3309        213  0.00%  0.02%  0.00%   0 LOCAL AAA          50           1         2        500  0.00%  0.00%  0.00%   0 AAA Cached Serve   51           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA         52           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA           54           0         2          0  0.00%  0.00%  0.00%   0 TPLUS              55           0         3          0  0.00%  0.00%  0.00%   0 Crypto WUI         56           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr   57           1         3        333  0.00%  0.00%  0.00%   0 Soap Consoleless   58           6         4       1500  0.00%  0.00%  0.00%   0 Crypto CA          59           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL     60           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL         61           3        16        187  0.00%  0.00%  0.00%   0 AAA SEND STOP EV   62           0         2          0  0.00%  0.00%  0.00%   0 Dot11 LBS Proc     63           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps       65           0        50          0  0.00%  0.00%  0.00%   0 DHCPD Timer        66           8      6027          1  0.00%  0.00%  0.00%   0 DHCP Client        67        8349     84826         98  0.55%  0.17%  0.10%   0 HyBridge Input P   68          14      6744          2  0.00%  0.00%  0.00%   0 Tbridge Monitor    69           0         2          0  0.00%  0.00%  0.00%   0 Spanning Tree      70           0      1690          0  0.00%  0.00%  0.00%   0 DHCPD Database  ------------------ show process cpu history ------------------ AP_WLAN_Bakery   12:32:06 PM Friday Oct 15 2010 -0400        1133333                                                       667777766666                                              100                                                             90                                                             80                                                             70                                                             60                                                             50                                                             40   *****                                                     30   *****                                                     20 *******                                                     10 ************                                                   0....5....1....1....2....2....3....3....4....4....5....5....              0    5    0    5    0    5    0    5    0    5                   CPU% per second (last 60 seconds)        7 37  78   7  8                                     11      121961  87   1  3       1    1       100                                                             90                               *                             80                              **      *                      70                        *  *  **   *  *                      60                        *  *  **   *  *                      50                        *  *  **   *  *                      40                        * **  **   *  *                      30                        * **  **   *  *                      20                        * **  #*   *  *                      10                        #*##  ##   #  #                         0....5....1....1....2....2....3....3....4....4....5....5....              0    5    0    5    0    5    0    5    0    5                   CPU% per minute (last 60 minutes)               * = maximum CPU%   # = average CPU%        8        8        100        90 *        80 *        70 *        60 *        50 *        40 *        30 *        20 *        10 *        0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.              0    5    0    5    0    5    0    5    0    5    0    5    0                    CPU% per hour (last 72 hours)                   * = maximum CPU%   # = average CPU% ------------------ show dot11 associations all-client ------------------ ------------------ show wlccp ap mobility traffic ------------------ ------------------ show wlccp ap mobility forwarding ------------------ ------------------ show inventory ------------------ NAME: "AP1210", DESCR: "Cisco Aironet 1200 Series Access Point" PID: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ, VID: ÿÿÿ, SN: FTX0902R2V1 ------------------ Mempool statistics ------------------                 Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b) Processor     A4AB84     4709500     2431000     2278500     1920552     2125904       I/O     ECB000     1265664      468008      797656      727168      779580 ------------------ show memory summary -----------------           Processor memory Alloc PC        Size     Blocks      Bytes    What 0x4790    0000000080 0000000001 0000000080    ACL Header 0x47A4    0000000024 0000000001 0000000024    Init 0x9FD4    0000000036 0000000001 0000000036    Init 0x9FFC    0000000040 0000000001 0000000040    Init 0xA018    0000000024 0000000001 0000000024    Init 0xA040    0000000036 0000000001 0000000036    Init 0xA134    0000000060 0000000001 0000000060    Init 0xF9D0    0000000024 0000000001 0000000024    HTTP CP 0xFAF8    0000000024 0000000001 0000000024    HTTP CP 0xFB6C    0000000076 0000000001 0000000076    HTTP CP 0xFC04    0000000024 0000000001 0000000024    HTTP CP 0xFC60    0000000028 0000000001 0000000028    HTTP CP 0xFD58    0000000024 0000000001 0000000024    Init 0xFDC4    0000000024 0000000001 0000000024    Init 0xFF2C    0000000036 0000000001 0000000036    HTTP CP 0xFF2C    0000000044 0000000001 0000000044    HTTP CP 0x11034   0000000024 0000000001 0000000024    Init 0x15750   0000004096 0000000001 0000004096    Init 0x1DD08   0000000120 0000000001 0000000120    Ion New Block 0x1F474   0000000024 0000000001 0000000024    LOGIN UNC PW 0x1F474   0000000056 0000000001 0000000056    LOGIN PWC (Free Blocks) 0x1F610   0000000080 0000000001 0000000080    local_aaa_authen2 (Free Blocks) 0x24F64   0000004784 0000000001 0000004784    (coalesced) (Free Blocks) 0x24F64   0000013956 0000000001 0000013956    (coalesced) (Free Blocks) 0x264F4   0000000512 0000000001 0000000512    Init 0x2CDF8   0000004312 0000000001 0000004312    TTY data 0x2E994   0000001500 0000000001 0000001500    String-DB entries 0x2E9BC   0000001500 0000000001 0000001500    String-DB owners 0x2E9E4   0000000776 0000000001 0000000776    String-DB handles 0x2E9FC   0000001024 0000000001 0000001024    String DB Hash Table 0x2F154   0000000024 0000000002 0000000048    SDB String 0x2F714   0000000176 0000000001 0000000176    SDB Owner info 0x2FF28   0000004312 0000000006 0000025872    TTY data 0x336E8   0000002000 0000000001 0000002000    TTY Input Buf 0x33720   0000000512 0000000001 0000000512    TTY Output Buf 0x3E6C0   0000000052 0000000003 0000000156    MAC ADDR subblock 0x40DA8   0000003000 0000000002 0000006000    keepalive sb chunk 0x42490   0000065536 0000000001 0000065536    Parseinfo Blocks 0x424B8   0000000364 0000000001 0000000364    tokenQ node 0x424E0   0000000432 0000000001 0000000432    Chain Cache Nodes 0x42508   0000032768 0000000001 0000032768    Parse Nodes 0x46E18   0000000120 0000000001 0000000120    Init 0x47028   0000000060 0000000001 0000000060    Init 0x47458   0000000024 0000000034 0000000816    Init 0x4755C   0000010000 0000000001 0000010000    Parser Linkage 0x47938   0000000056 0000000053 0000002968    Parser Mode 0x47938   0000000108 0000000001 0000000108    Parser Mode 0x479A4   0000000024 0000000054 0000001296    Parser Mode Q1 0x479C8   0000000024 0000000054 0000001296    Parser Mode Q2 0x49FA8   0000000432 0000000001 0000000432    Chain Cache No 0x4A070   0000000432 0000000009 0000003888    Chain Cache No 0x4A070   0000000432 0000000001 0000000432    Chain Cache No (Free Blocks) 0x4A070   0000000548 0000000001 0000000548    (coalesced) (Free Blocks) 0x4A160   0000000432 0000000001 0000000432    Chain Cache No 0x4FCD4   0000000256 0000000001 0000000256    HTTP CP 0x548F4   0000000032 0000000016 0000000512    Parser Alias 0x54924   0000000024 0000000016 0000000384    Init 0x5C338   0000004616 0000000001 0000004616    (coalesced) (Free Blocks) 0x5D464   0000000024 0000000001 0000000024    HTTP CP 0x5D4E4   0000000024 0000000001 0000000024    HTTP CP 0x65394   0000000024 0000000008 0000000192    Cond Debug definition 0x698F0   0000000068 0000000003 0000000204    GraphIt Data 0x6990C   0000001316 0000000003 0000003948    Graphit Client 0x69920   0000000024 0000000002 0000000048    Init 0x69920   0000000032 0000000001 0000000032    Init 0x73254   0000000164 0000000002 0000000328    Init 0x73278   0000000164 0000000002 0000000328    Init 0x7329C   0000000164 0000000002 0000000328    Init 0x7B12C   0000000164 0000000001 0000000164    Init 0x7B150   0000000164 0000000001 0000000164    Init 0x7B174   0000000164 0000000001 0000000164    Init 0x83E48   0000000060 0000000001 0000000060    HTTP CP 0x842C0   0000000044 0000000001 0000000044    HTTP CP 0x86C40   0000032772 0000000001 0000032772    Init 0x8AD2C   0000000024 0000000002 0000000048    AAA Secrettype 0x8AD64   0000000024 0000000002 0000000048    AAA Secrettype encrypt 0x8ADD0   0000000024 0000000002 0000000048    AAA_Secrettype pw 0x8B254   0000000192 0000000002 0000000384    AAA SG HEAD 0x8B294   0000000024 0000000002 0000000048    AAA SG NAME 0x8BFA8   0000000060 0000000001 0000000060    AAA MI SG NAME 0x8D1AC   0000003200 0000000001 0000003200    AAA attr list handle IDs 0x8DBA8   0000001024 0000000001 0000001024    AAA attr list handle IDs 0x9AE18   0000004096 0000000001 0000004096    AAA Unique Id Hash Table 0x9AED8   0000065536 0000000001 0000065536    AAA DB Chunk 0x9EFE8   0000020000 0000000001 0000020000    AAA Acct DB chunk 0xA0EA0   0000016336 0000000001 0000016336    AAA Acct Rec chunk 0xAFBC4   0000002048 0000000001 0000002048    AAA SG ID table 0xAFE78   0000001024 0000000003 0000003072    AAA SG ID table 0xB3D68   0000000032 0000000001 0000000032    Init 0xB4388   0000000024 0000000001 0000000024    AAA nvgend sg elt 0xB4388   0000000052 0000000001 0000000052    AAA nvgend sg elt 0xB43C0   0000000132 0000000002 0000000264    AAA Public Server Group 0xB4400   0000000028 0000000002 0000000056    AAA Public Server Group wrapper 0xB4448   0000000024 0000000002 0000000048    AAA pub SG servers 0xB44CC   0000000024 0000000002 0000000048    AAA pub SG wrap name 0xB4510   0000000024 0000000002 0000000048    AAA pub SG name 0xBC014   0000000776 0000000275 0000213400    *Free Packet Header* 0xBC014   0000000788 0000000001 0000000788    *Free Packet Header* 0xBC014   0000000804 0000000001 0000000804    *Free Packet Header* 0xBC014   0000000828 0000000001 0000000828    *Free Packet Header* 0xBC014   0000001408 0000000001 0000001408    (coalesced) (Free Blocks) 0xBC014   0000008480 0000000001 0000008480    (coalesced) (Free Blocks) 0xBCA88   0000000776 0000000003 0000002328    *In-use Packet Header* 0xC1274   0000004000 0000000001 0000004000    Packet Elements 0xC3B00   0000000184 0000000001 0000000184    IRB/CRB rxtypes 0xC3EE4   0000004712 0000000005 0000023560    *Hardware IDB* 0xC3EFC   0000001400 0000000005 0000007000    *Software IDB* 0xC4440   0000000024 0000000003 0000000072    HTTP CP 0xC4440   0000000076 0000000001 0000000076    HTTP CP 0xC4494   0000000024 0000000003 0000000072    HTTP CP 0xC4494   0000000080 0000000001 0000000080    HTTP CP 0xC4580   0000000184 0000000004 0000000736    IRB/CRB rxtypes 0xC4948   0000000048 0000000001 0000000048    HTTP CP 0xC4948   0000000052 0000000001 0000000052    HTTP CP 0xC4CB8   0000001400 0000000004 0000005600    *Software IDB* 0xC5864   0000000024 0000000004 0000000096    Init 0xC58E0   0000000024 0000000004 0000000096    Init 0xC8118   0000000032 0000000004 0000000128    IP Input 0xED1F0   0000035292 0000000001 0000035292    IDB List Element Chunks 0xFF3C0   0000000024 0000000059 0000001416    Init 0xFF7C4   0000000104 0000000008 0000000832    Init 0xFF7D4   0000000024 0000000006 0000000144    Init 0xFF7D4   0000000076 0000000001 0000000076    Init 0xFF7D4   0000000080 0000000001 0000000080    Init 0xFF8F4   0000000024 0000000001 0000000024    Init 0xFF9A4   0000000024 0000000007 0000000168    Init 0x102F38  0000010000 0000000001 0000010000    AAA chunk 0x103140  0000004616 0000000001 0000004616    AAA Acct AVLnode chunk 0x107F7C  0000000100 0000000001 0000000100    AAA MLIST 0x1081E8  0000000092 0000000001 0000000092    AAA MLIST 0x108A7C  0000001024 0000000002 0000002048    AAA mlist ID table 0x118430  0000001500 0000000007 0000010500    List Elements 0x119688  0000001500 0000000001 0000001500    List Elements 0x1196C8  0000005000 0000000001 0000005000    List Headers 0x11D7D4  0000001032 0000000001 0000001032    Process Array 0x11F5B0  0000000640 0000000068 0000043520    Process 0x11F5B0  0000000856 0000000001 0000000856    (coalesced) (Free Blocks) 0x1213A8  0000001500 0000000001 0000001500    Watched Semaph 0x1219A4  0000000144 0000000064 0000009216    Process Events 0x1219A4  0000000160 0000000002 0000000320    Process Events 0x1219A4  0000000172 0000000001 0000000172    Process Events 0x1219A4  0000000200 0000000001 0000000200    Process Events 0x1219A4  0000000208 0000000001 0000000208    Process Events 0x1219A4  0000000256 0000000001 0000000256    (coalesced) (Free Blocks) 0x1219A4  0000000432 0000000001 0000000432    (coalesced) (Free Blocks) 0x1219A4  0000000556 0000000001 0000000556    (coalesced) (Free Blocks) 0x123C24  0000001500 0000000001 0000001500    messages 0x123C50  0000001500 0000000001 0000001500    Watched messages 0x123C7C  0000010000 0000000001 0000010000    Watched Queue 0x123CA4  0000005000 0000000001 0000005000    Watched Boolean 0x123CCC  0000005000 0000000001 0000005000    Watched Bitfield 0x123CF4  0000001500 0000000001 0000001500    Watched Semaphore 0x123D18  0000005000 0000000001 0000005000    Watcher Info 0x123D40  0000000500 0000000001 0000000500    Watched Message Queue 0x123D68  0000001500 0000000001 0000001500    Watcher Message Queue 0x123D90  0000003000 0000000001 0000003000    Read/Write Locks 0x126050  0000002000 0000000001 0000002000    Reg Function 12 0x126078  0000001500 0000000001 0000001500    Reg Function iList 0x1260A0  0000001500 0000000001 0000001500    Reg Function Caselist 0x126118  0000002000 0000000005 0000010000    Reg Function 1 0x12657C  0000002000 0000000001 0000002000    Reg Function 1 0x129F50  0000000024 0000000002 0000000048    *Sched* 0x129F50  0000000032 0000000001 0000000032    *Sched* 0x129F50  0000000044 0000000008 0000000352    *Sched* 0x12A228  0000000256 0000000001 0000000256    Init 0x12C5F8  0000003000 0000000001 0000003000    CCA CCB chunks 0x12CDBC  0000000048 0000000008 0000000384    CCA Component 0x12CE24  0000000024 0000000007 0000000168    CCA Notification Flags 0x12CE24  0000000048 0000000001 0000000048    CCA Notification Flags 0x12CE84  0000003000 0000000008 0000024000    Keepalive 0x12CFF4  0000000024 0000000003 0000000072    CCA UserType 0x12D0A8  0000003000 0000000001 0000003000    CCA CLA chunks 0x1301C0  0000000024 0000000001 0000000024    TW Wheels 0x130200  0000016384 0000000003 0000049152    TW Buckets 0x13AA18  0000000112 0000000006 0000000672    Process Signals 0x13B01C  0000003000 0000000001 0000003000    Process Stack 0x13B01C  0000005500 0000000049 0000269500    Process Stack 0x13B01C  0000008000 0000000004 0000032000    Process Stack 0x13B01C  0000009000 0000000006 0000054000    Process Stack 0x13B01C  0000011000 0000000009 0000099000    Scheduler Stack 0x13B01C  0000018000 0000000001 0000018000    Interrupt Stack 0x13B01C  0002125900 0000000001 0002125900    (coalesced) (Free Blocks) 0x14F6BC  0000020000 0000000001 0000020000    Managed Chunk Queue Elements 0x151870  0000000068 0000000001 0000000068    (fragment) (Free Blocks) 0x1559A8  0000000296 0000000008 0000002368    Pool Info 0x155F84  0000000032 0000000001 0000000032    Pool Cache 0x15AF2C  0000000264 0000000001 0000000264    CLASSMAP_MODULE 0x15B7B0  0000000104 0000000001 0000000104    CLASSMAP_MODULE 0x15B8D0  0000000136 0000000001 0000000136    CLASSMAP_MODULE 0x15B8F0  0000000024 0000000001 0000000024    CLASSMAP_MODULE 0x15BA20  0000000024 0000000001 0000000024    CLASSMAP_MODULE 0x1826A8  0000000256 0000000001 0000000256    Init 0x182B78  0000000256 0000000001 0000000256    Init 0x1875C0  0000000776 0000000002 0000001552    *In-use Packet Header* 0x188DF4  0000000288 0000000003 0000000864    SNTP 0x188DF4  0000000332 0000000001 0000000332    DDP 0x1904D0  0000000776 0000000001 0000000776    *In-use Packet Header* 0x193CB8  0000001184 0000000005 0000005920    TCP CB 0x193CB8  0000000728 0000000001 0000000728    (fragment) (Free Blocks) 0x1A86AC  0000003000 0000000001 0000003000    IP Addresses 0x1AE490  0000000024 0000000004 0000000096    HTTP CP 0x1AE490  0000000032 0000000001 0000000032    Dot11 driver 0x1AE490  0000000048 0000000001 0000000048    AiroIAPP Protocol 0x1AE490  0000000068 0000000001 0000000068    HTTP CP 0x1CDDA0  0000000280 0000000004 0000001120    Init 0x1CDDAC  0000000068 0000000004 0000000272    Init 0x1EB928  0000005000 0000000001 0000005000    ip localpool 0x1EFFC4  0000000024 0000000001 0000000024    Init 0x1F9E40  0000001652 0000000003 0000004956    HTTP CORE 0x1F9EC8  0000000128 0000000003 0000000384    DHCPD Receive 0x1FBF20  0000000172 0000000002 0000000344    DHCPD Receive 0x1FBF20  0000000232 0000000001 0000000232    HTTP CORE 0x1FBF20  0000000500 0000000001 0000000500    (coalesced) (Free Blocks) 0x1FF2DC  0000000040 0000000001 0000000040    DHCPD Receive 0x206B78  0000000024 0000000003 0000000072    Init 0x206BA8  0000000024 0000000003 0000000072    Init 0x20BE88  0000001500 0000000001 0000001500    Syslogd Messages chunk 0x20FEF0  0000000024 0000000001 0000000024    Init 0x221B18  0000010000 0000000001 0000010000    Time Range Entry Chunks 0x221B40  0000003000 0000000001 0000003000    Time Range Item Chunks 0x221B68  0000001500 0000000001 0000001500    Time Range User Chunks 0x2221E4  0000000036 0000000016 0000000576    Init 0x222214  0000000040 0000000016 0000000640    Init 0x2233CC  0000005000 0000000001 0000005000    File Descriptors 0x223F04  0000000024 0000000003 0000000072    Init 0x228910  0000010000 0000000001 0000010000    Pathents for parsing 0x228994  0000001368 0000000001 0000001368    Init 0x22B998  0000000028 0000000002 0000000056    Init 0x22F7C8  0000000280 0000000001 0000000280    Init 0x23B404  0000091496 0000000001 0000091496    (coalesced) (Free Blocks) 0x24786C  0000000432 0000000001 0000000432    (coalesced) (Free Blocks) 0x24E0A8  0000000100 0000000001 0000000100    HTTP CP (Free Blocks) 0x2500F4  0000000024 0000000154 0000003696    soap_flash init 0x2500F4  0000000028 0000000001 0000000028    HTTP CP 0x2500F4  0000000032 0000000001 0000000032    HTTP CP 0x2500F4  0000000044 0000000001 0000000044    HTTP CP 0x2501D0  0000010000 0000000016 0000160000    Flashfs Sector 0x254748  0000010000 0000000001 0000010000    Flashfs Sector Pointers 0x255270  0000000176 0000000001 0000000176    soap_flash init 0x2553C8  0000000976 0000000001 0000000976    soap_flash init 0x255508  0000005000 0000000001 0000005000    Flashfs Sector buffers 0x255860  0000000028 0000000001 0000000028    HTTP CP (Free Blocks) 0x259D4C  0000000024 0000000026 0000000624    soap_flash init 0x259D5C  0000000024 0000000025 0000000600    soap_flash init 0x259D5C  0000000028 0000000001 0000000028    soap_flash init 0x259D7C  0000000024 0000000024 0000000576    soap_flash init 0x259D7C  0000000048 0000000001 0000000048    HTTP CP 0x259D7C  0000000060 0000000001 0000000060    soap_flash init 0x25E418  0000000036 0000000001 0000000036    soap_flash init 0x25E434  0000000036 0000000001 0000000036    soap_flash init 0x25E488  0000000744 0000000001 0000000744    soap_flash init 0x25E534  0000000024 0000000001 0000000024    soap_flash init 0x25E638  0000000036 0000000001 0000000036    soap_flash init 0x25E654  0000000036 0000000001 0000000036    soap_flash init 0x25E6CC  0000000732 0000000001 0000000732    soap_flash init 0x25E778  0000000024 0000000001 0000000024    soap_flash init 0x25FC8C  0000000024 0000000001 0000000024    soap_flash init 0x2647C0  0000000024 0000000001 0000000024    soap_flash init 0x2647F0  0000000768 0000000001 0000000768    soap_flash init 0x26483C  0000000036 0000000001 0000000036    soap_flash init 0x2699E0  0000003000 0000000001 0000003000    ARP Entry 0x269C14  0000000040 0000000001 0000000040    Init 0x2A06FC  0000000480 0000000001 0000000480    Acct system ustruct 0x2A768C  0000008800 0000000001 0000008800    PPP ACC LISTS 0x2A76D8  0000008000 0000000001 0000008000    NET AUTHOR LISTS 0x2A771C  0000000024 0000000001 0000000024    AAA PROMPT P1 0x2A7738  0000000024 0000000001 0000000024    AAA PROMPT U1 0x2AFBD4  0000009600 0000000001 0000009600    NET ACCT LISTS 0x2AFC20  0000009600 0000000001 0000009600    SYS ACCT LISTS 0x2B2020  0000000024 0000000001 0000000024    Init 0x2B20F8  0000000084 0000000001 0000000084    Init 0x2C6B60  0000012784 0000000001 0000012784    DHCPD Message Workspace 0x2C81D4  0000000220 0000000001 0000000220    DHCPD Radix Information Nodes 0x2C81D4  0000000776 0000000001 0000000776    DHCPD Radix Information Nodes 0x2CF494  0000000024 0000000001 0000000024    Init 0x2CF4CC  0000000024 0000000001 0000000024    Init 0x2D12C8  0000000024 0000000001 0000000024    Init 0x2D14CC  0000000024 0000000001 0000000024    Init 0x2D1738  0000000076 0000000001 0000000076    Init 0x2D1938  0000000024 0000000001 0000000024    Init 0x2D1A24  0000000024 0000000001 0000000024    Init 0x2D1B20  0000000024 0000000001 0000000024    Init 0x2D1D4C  0000000024 0000000001 0000000024    Init 0x2D1E04  0000000024 0000000001 0000000024    Init 0x2D2084  0000000024 0000000001 0000000024    Init 0x2D8A44  0000000024 0000000001 0000000024    Init 0x2D8A54  0000000024 0000000001 0000000024    Init 0x2D9C58  0000000024 0000000001 0000000024    Init 0x2DAF24  0000005020 0000000001 0000005020    Init 0x2DBE34  0000000080 0000000001 0000000080    Init 0x2DBEB4  0000000080 0000000004 0000000320    Init 0x2F048C  0000000024 0000000002 0000000048    Init 0x2F048C  0000000048 0000000001 0000000048    Init 0x2F38DC  0000000024 0000000017 0000000408    SNMP Trap 0x2F38DC  0000000048 0000000001 0000000048    SNMP Trap 0x2F9D88  0000000024 0000000007 0000000168    Init 0x2F9D88  0000000028 0000000002 0000000056    Init 0x2F9D88  0000000060 0000000002 0000000120    Init 0x2F9D88  0000000192 0000000001 0000000192    Init 0x2F9D88  0000000252 0000000001 0000000252    Init 0x2F9F68  0000010000 0000000001 0000010000    SNMP SMALL CHUNK 0x2F9FB0  0000010000 0000000001 0000010000    SNMP MEDIUM CHUNK 0x2FA004  0000002000 0000000001 0000002000    SNMP BIG CHUNK 0x2FA0F8  0000000776 0000000001 0000000776    SNMP VB CHUNK 0x2FA768  0000002048 0000000001 0000002048    Init 0x2FAA68  0000000024 0000000002 0000000048    Init 0x2FAD80  0000000024 0000000001 0000000024    HTTP CP 0x2FAD80  0000000040 0000000001 0000000040    HTTP CP 0x2FAD80  0000000072 0000000001 0000000072    HTTP CP 0x2FAD80  0000000076 0000000001 0000000076    HTTP CP 0x2FC4F0  0000000036 0000000001 0000000036    Entity MIB API 0x2FC560  0000000060 0000000001 0000000060    Entity MIB API 0x2FC5D0  0000000144 0000000003 0000000432    Entity MIB API 0x2FC5F0  0000000040 0000000001 0000000040    Entity MIB API 0x2FC5F0  0000000044 0000000001 0000000044    Entity MIB API 0x2FC5F0  0000000060 0000000001 0000000060    Entity MIB API 0x2FC620  0000000024 0000000001 0000000024    Entity MIB API 0x2FC620  0000000060 0000000001 0000000060    Entity MIB API 0x2FC620  0000000076 0000000001 0000000076    Entity MIB API 0x2FC634  0000000028 0000000001 0000000028    Entity MIB API 0x2FC634  0000000040 0000000001 0000000040    Entity MIB API 0x2FC64C  0000000024 0000000001 0000000024    Entity MIB API 0x2FC658  0000000024 0000000001 0000000024    Entity MIB API 0x2FC658  0000000052 0000000001 0000000052    Entity MIB API 0x2FC664  0000000024 0000000001 0000000024    Entity MIB API 0x2FC664  0000000060 0000000001 0000000060    Entity MIB API 0x2FC670  0000000024 0000000001 0000000024    Entity MIB API 0x2FC734  0000000024 0000000002 0000000048    Entity MIB API 0x2FCBB8  0000000024 0000000003 0000000072    Entity MIB API 0x2FCBDC  0000000024 0000000003 0000000072    Entity MIB API 0x2FCC1C  0000000024 0000000003 0000000072    Entity MIB API 0x2FECA4  0000000024 0000000005 0000000120    HTTP CP 0x2FECA4  0000000040 0000000003 0000000120    HTTP CP 0x2FECA4  0000000048 0000000002 0000000096    HTTP CP 0x301A58  0000000064 0000000001 0000000064    Init 0x3071A4  0000000036 0000000001 0000000036    HTTP CP (Free Blocks) 0x3072A8  0000000064 0000000001 0000000064    HTTP CP (Free Blocks) 0x30BE58  0000000064 0000000001 0000000064    HTTP 0x30C970  0000000064 0000000001 0000000064    HTTP 0x30D38C  0000000024 0000000029 0000000696    HTTP 0x30D38C  0000000044 0000000001 0000000044    HTTP 0x30D38C  0000000048 0000000001 0000000048    HTTP 0x30D38C  0000000064 0000000001 0000000064    HTTP 0x30D758  0000000044 0000000016 0000000704    HTTP 0x30D758  0000000052 0000000015 0000000780    HTTP 0x30D758  0000000104 0000000001 0000000104    HTTP 0x30DB70  0000000040 0000000001 0000000040    HTTP 0x30F3F0  0000000136 0000000001 0000000136    HTTP 0x30F510  0000000036 0000000003 0000000108    HTTP 0x30F6DC  0000000544 0000000001 0000000544    HTTP 0x30F6DC  0000000720 0000000001 0000000720    (fragment) (Free Blocks) 0x30F6DC  0000000776 0000000002 0000001552    (coalesced) (Free Blocks) 0x30F6DC  0000001112 0000000001 0000001112    (coalesced) (Free Blocks) 0x30F6DC  0000001184 0000000001 0000001184    (coalesced) (Free Blocks) 0x30F6DC  0000001452 0000000001 0000001452    (coalesced) (Free Blocks) 0x30F6DC  0000001776 0000000001 0000001776    (coalesced) (Free Blocks) 0x311774  0000000032 0000000001 0000000032    HTTP 0x311774  0000000036 0000000001 0000000036    HTTP 0x311774  0000000032 0000000001 0000000032    (fragment) (Free Blocks) 0x311774  0000000052 0000000001 0000000052    (fragment) (Free Blocks) 0x313A48  0000000060 0000000001 0000000060    HTTP 0x313A48  0000000024 0000000001 0000000024    (fragment) (Free Blocks) 0x317330  0000000024 0000000001 0000000024    AAA Attr String (Free Blocks) 0x317330  0000000032 0000000001 0000000032    AAA Attr String (Free Blocks) 0x317330  0000000544 0000000001 0000000544    (coalesced) (Free Blocks) 0x317BFC  0000000024 0000000001 0000000024    AAA Attr String (Free Blocks) 0x317BFC  0000000048 0000000001 0000000048    AAA Attr String (Free Blocks) 0x318000  0000000060 0000000001 0000000060    HTTP CORE 0x31B9C0  0000000256 0000000001 0000000256    HTTP 0x31B9C0  0000000316 0000000001 0000000316    HTTP 0x31B9C0  0000000408 0000000001 0000000408    (coalesced) (Free Blocks) 0x31B9C0  0000000640 0000000001 0000000640    (coalesced) (Free Blocks) 0x31B9C0  0000001184 0000000001 0000001184    (coalesced) (Free Blocks) 0x31B9C0  0000004548 0000000001 0000004548    (coalesced) (Free Blocks) 0x31C5D4  0000000576 0000000001 0000000576    HTTP 0x3213BC  0000000824 0000000001 0000000824    HTTP 0x321884  0000002956 0000000001 0000002956    HTTP 0x321884  0000003252 0000000001 0000003252    (coalesced) (Free Blocks) 0x321884  0000003648 0000000001 0000003648    (coalesced) (Free Blocks) 0x322E78  0000004096 0000000001 0000004096    HTTP 0x322EA4  0000005000 0000000001 0000005000    HTTP_SMALL_CHUNK 0x326574  0000004700 0000000001 0000004700    HTTPS_MSG_CHUNK 0x3266B4  0000000128 0000000001 0000000128    HTTP 0x3266B4  0000000028 0000000001 0000000028    (fragment) (Free Blocks) 0x32877C  0000000076 0000000004 0000000304    HTTP 0x328E60  0000000112 0000000001 0000000112    HTTP 0x32C2C8  0000000164 0000000001 0000000164    HTTP 0x32F23C  0000004616 0000000001 0000004616    HTTP 1.1 Redirection Controller 0x339340  0000000040 0000000001 0000000040    HTTP CP 0x339340  0000000072 0000000001 0000000072    (fragment) (Free Blocks) 0x349F2C  0000000056 0000000008 0000000448    SNMP IDB 0x349FF0  0000000064 0000000008 0000000512    IfMib Element 0x34A7EC  0000000024 0000000003 0000000072    Init 0x34A7EC  0000000028 0000000001 0000000028    Init 0x34A800  0000000024 0000000004 0000000096    Init 0x34B064  0000000024 0000000001 0000000024    HTTP CP 0x34B064  0000000048 0000000002 0000000096    HTTP CP 0x34B064  0000000052 0000000001 0000000052    HTTP CP 0x34B0E8  0000000024 0000000001 0000000024    HTTP CP 0x34B0E8  0000000028 0000000001 0000000028    HTTP CP 0x34B0E8  0000000032 0000000001 0000000032    HTTP CP 0x34B0E8  0000000088 0000000001 0000000088    HTTP CP 0x34B114  0000000024 0000000003 0000000072    HTTP CP 0x34B114  0000000080 0000000001 0000000080    HTTP CP 0x34B5C0  0000000024 0000000002 0000000048    Init 0x34C14C  0000000044 0000000001 0000000044    Init 0x34C448  0000000032 0000000001 0000000032    Init 0x34C448  0000000036 0000000001 0000000036    Init 0x34C448  0000000040 0000000001 0000000040    Init 0x34C448  0000000044 0000000001 0000000044    Init 0x34C448  0000000060 0000000002 0000000120    HTTP CP 0x34C448  0000000064 0000000002 0000000128    HTTP CP 0x34CA64  0000000024 0000000001 0000000024    IFINDEX hw subblock 0x34CA64  0000000048 0000000002 0000000096    IFINDEX hw subblock 0x359000  0000000072 0000000001 0000000072    SNTP process block 0x359D50  0000000056 0000000001 0000000056    SNTP server 0x360138  0000000320 0000000001 0000000320    Spanning Tree Opt Tree Block 0x360180  0000025600 0000000001 0000025600    Spanning Tree Opt Port Block 0x3604F4  0000000352 0000000001 0000000352    stp_timer_tree_type 0x361F94  0000000304 0000000002 0000000608    Spanning Tree Control Block 0x362BF4  0000000336 0000000004 0000001344    Spanning Tree Port Control Block 0x38129C  0000000024 0000000002 0000000048    HTTP CP 0x38129C  0000000044 0000000001 0000000044    HTTP CP 0x38129C  0000000080 0000000001 0000000080    HTTP CP 0x382980  0000000024 0000000001 0000000024    Init 0x38FB08  0000000104 0000000004 0000000416    DOT1Q SW subblock 0x398C70  0000000080 0000000003 0000000240    HTTP CP 0x398C70  0000000100 0000000001 0000000100    HTTP CP 0x398CF0  0000000036 0000000004 0000000144    HTTP CP 0x399F70  0000000128 0000000001 0000000128    HTTP CP 0x399F70  0000000148 0000000001 0000000148    HTTP CP 0x39A848  0000000280 0000000002 0000000560    DOT1Q HW subblock 0x39AA4C  0000000256 0000000002 0000000512    ÜVx» 0x39EFB0  0000032768 0000000001 0000032768    .1Q[Tree Nodes] 0x39EFE4  0000010372 0000000001 0000010372    .1Q[Tree Headers] 0x39F018  0000010000 0000000001 0000010000    .1Q[Array Headers] 0x3AF60C  0000000184 0000000002 0000000368    IRB route rxtypes 0x3B17B4  0000004592 0000000002 0000009184    tbridgetype 0x3B2434  0000060024 0000000001 0000060024    BTE Entries 0x3B61A8  0000000144 0000000004 0000000576    TB IFD flood list 0x3BB2A0  0000001024 0000000006 0000006144    SMF filter 0x3BB460  0000000024 0000000024 0000000576    SMF entry 0x3BB460  0000000036 0000000002 0000000072    SMF entry 0x3BB460  0000000040 0000000001 0000000040    SMF entry 0x3BB460  0000000044 0000000001 0000000044    SMF entry 0x3BB460  0000000052 0000000001 0000000052    SMF entry 0x3BB460  0000000060 0000000003 0000000180    SMF entry 0x3BB460  0000000068 0000000003 0000000204    SMF entry 0x3BB460  0000000072 0000000001 0000000072    SMF entry 0x3BB460  0000000076 0000000001 0000000076    SMF entry 0x3BB460  0000000080 0000000001 0000000080    SMF entry 0x3C006C  0000000024 0000000003 0000000072    STP subblock 0x3C006C  0000000036 0000000001 0000000036    STP subblock 0x3C2AF0  0000000024 0000000002 0000000048    bridge group name 0x3DE28C  0000000232 0000000001 0000000232    CDP Protocol 0x3DE28C  0000000268 0000000001 0000000268    CDP Protocol 0x3DE28C  0000000272 0000000001 0000000272    CDP Protocol 0x3DF388  0000000024 0000000001 0000000024    HTTP CP 0x3E3390  0000000268 0000000001 0000000268    Init 0x3E3C54  0000000028 0000000001 0000000028    CDP Protocol 0x3E3C54  0000000036 0000000001 0000000036    CDP Protocol 0x3E3C54  0000000048 0000000001 0000000048    CDP Protocol 0x3E3DA0  0000000100 0000000002 0000000200    CDP Protocol 0x3E3DA0  0000000104 0000000001 0000000104    CDP Protocol 0x3E4AF8  0000000232 0000000003 0000000696    CDP Protocol 0x3E6B68  0000000064 0000000005 0000000320    CDP sw subblock 0x3E6B68  0000000100 0000000001 0000000100    CDP sw subblock 0x3E6C20  0000000024 0000000001 0000000024    CDP hw subblock 0x3E6C20  0000000044 0000000001 0000000044    CDP hw subblock 0x3EE998  0000001028 0000000001 0000001028    DHCPD Database Workspace 0x412354  0000000380 0000000001 0000000380    Init 0x41239C  0000004160 0000000001 0000004160    Init 0x41D488  0000000956 0000000004 0000003824    Dot11 driver 0x4212D0  0000107280 0000000001 0000107280    802.11 driver Instance 0x42131C  0000001596 0000000001 0000001596    dot11 HAL 0x4215F8  0000001200 0000000001 0000001200    Init 0x421A20  0000005000 0000000001 0000005000    Dot11 driver beacon IE chunk 0x4385B8  0000032768 0000000001 0000032768    dot11drvr clients 0x4385E4  0000000296 0000000001 0000000296    dot11drvr subblks 0x438608  0000001500 0000000001 0000001500    dot11drvr assoc info 0x44264C  0000000024 0000000001 0000000024    dot11 aaa subblock 0x451050  0000020000 0000000001 0000020000    Dot11 Pmkid Record Chunks 0x451870  0000001112 0000000001 0000001112    dot11 mgmt subblock 0x4574A8  0000007260 0000000001 0000007260    Dot11 Mgmt Client Send Fail Event Chunk 0x4574E0  0000007260 0000000001 0000007260    Dot11 Mgmt Client Not Found Event Chunk 0x45E1C8  0000065536 0000000001 0000065536    Dot11 Mgmt Station  Chunk 0x46067C  0000020000 0000000001 0000020000    Dot11 Mgmt SSID  Chunk 0x4606B4  0000032768 0000000001 0000032768    Dot11 Mgmt SSID Config. Chunk 0x4606EC  0000000776 0000000001 0000000776    Dot11 Mgmt SSID Intf Chunk 0x46087C  0000000064 0000000001 0000000064    Init 0x46443C  0000000024 0000000001 0000000024    HTTP CP 0x465910  0000000028 0000000001 0000000028    HTTP CP 0x465EAC  0000000400 0000000002 0000000800    HTTP CP 0x467C68  0000000732 0000000001 0000000732    Wireless dynamic vlan Chunk 0x467CB8  0000001116 0000000001 0000001116    Wireless dynamic WNID Chunk 0x469F48  0000000524 0000000001 0000000524    Init 0x4A3CA8  0000000104 0000000001 0000000104    dot11 wids subblock 0x4AFBDC  0000000036 0000000001 0000000036    Init 0x4B388C  0000000684 0000000001 0000000684    Soap Upgrade fetch Config File 0x4B5E6C  0000000776 0000000011 0000008536    *In-use Packet Header* 0x4B9528  0000000380 0000000001 0000000380    Init 0x4BACEC  0000000776 0000000002 0000001552    *In-use Packet Header* 0x4C877C  0000000172 0000000001 0000000172    iapp triggered event chunk 0x4C877C  0000000720 0000000001 0000000720    iapp triggered event chunk 0x4C87F0  0000000188 0000000001 0000000188    WGB CLIENTS chunk 0x4C87F0  0000000296 0000000001 0000000296    WGB CLIENTS chunk 0x4CB868  0000000152 0000000001 0000000152    dot11 auth client chunk 0x4CB868  0000013200 0000000001 0000013200    dot11 auth client chunk 0x4CF554  0000000040 0000000002 0000000080    HTTP CP 0x4D0154  0000010000 0000000001 0000010000    DDP UDP tx  Chunk 0x52F1E0  0000000344 0000000001 0000000344    Syslog History 0x531E54  0000000032 0000000001 0000000032    Init 0x532704  0000000024 0000000001 0000000024    Init 0x53B99C  0000000072 0000000002 0000000144    Init 0x53B99C  0000000120 0000000001 0000000120    Init 0x53BA00  0000000048 0000000001 0000000048    Init 0x53BA58  0000000040 0000000002 0000000080    Init 0x53CD5C  0000000040 0000000004 0000000160    Tbridge sw subblock 0x53CD5C  0000000092 0000000002 0000000184    Tbridge sw subblock 0x53CD7C  0000000192 0000000005 0000000960    Tbridge swsb features 0x53CD7C  0000000228 0000000001 0000000228    Tbridge swsb features 0x5C25CC  0000000064 0000000002 0000000128    Crypto WUI 0x5C2608  0000000036 0000000001 0000000036    Crypto WUI 0x5DC14C  0000000024 0000000003 0000000072    Check heaps 0x5DC168  0000002048 0000000003 0000006144    Check heaps 0x5DC188  0000000128 0000000003 0000000384    Check heaps 0x5DC1B4  0000002048 0000000003 0000006144    Check heaps 0x5DC1E8  0000002048 0000000003 0000006144    Check heaps 0x628AE8  0000000024 0000000044 0000001056    Crypto CA 0x628AE8  0000000036 0000000001 0000000036    Crypto CA 0x628AE8  0000000044 0000000001 0000000044    Crypto CA 0x628AE8  0000000056 0000000001 0000000056    Crypto CA 0x628AE8  0000000064 0000000001 0000000064    Crypto CA 0x628AE8  0000000072 0000000001 0000000072    Crypto CA 0x628AE8  0000000120 0000000004 0000000480    Crypto CA 0x628AE8  0000000124 0000000001 0000000124    Crypto CA 0x628AE8  0000000128 0000000001 0000000128    Crypto CA 0x628AE8  0000000132 0000000001 0000000132    Crypto CA 0x628AE8  0000000144 0000000001 0000000144    Crypto CA 0x628AE8  0000000528 0000000001 0000000528    Crypto CA 0x641450  0000000364 0000000001 0000000364    Dot11 MN Helper Chunks 0x641D94  0000000032 0000000001 0000000032    Init 0x641D94  0000000076 0000000001 0000000076    Init 0x64AAB0  0000000028 0000000001 0000000028    Init 0x64AAB0  0000000032 0000000001 0000000032    Init 0x64AB50  0000000136 0000000002 0000000272    ENTMIB entPhysicalTable RBTree 0x6532F0  0000000024 0000000002 0000000048    Init 0x653308  0000000024 0000000001 0000000024    Init 0x653308  0000000028 0000000001 0000000028    Init 0x653334  0000000024 0000000002 0000000048    Init 0x65BEB0  0000000024 0000000002 0000000048    Init 0x65BEB0  0000000028 0000000001 0000000028    HTTP CORE 0x65BEB0  0000000060 0000000001 0000000060    Init 0x65BEB0  0000000072 0000000001 0000000072    Init 0x65BEB0  0000000084 0000000001 0000000084    Init 0x65CDA8  0000000256 0000000005 0000001280    Init 0x65E8EC  0000000256 0000000001 0000000256    DHCPD Internal Radix Tree Nodes 0x65E8EC  0000001756 0000000002 0000003512    access list 0x65E8EC  0000002000 0000000001 0000002000    DHCPD Internal Radix Tree Nodes 0x65E8EC  0000020000 0000000002 0000040000    access list 0x65FA7C  0000000024 0000000001 0000000024    Init 0x65FA94  0000000024 0000000001 0000000024    Init 0x65FB50  0000000036 0000000001 0000000036    Init 0x6621C0  0000001036 0000000004 0000004144    Minmax8u 0x6624AC  0000001028 0000000012 0000012336    Index Table Block 0x66DF6C  0000001024 0000000001 0000001024    HTTP CP 0x66E56C  0000001080 0000000001 0000001080    Init 0x66E56C  0000000108 0000000001 0000000108    (coalesced) (Free Blocks) 0x66EA88  0000000044 0000000066 0000002904    HTTP CORE 0x66EA88  0000000092 0000000003 0000000276    Init 0x66EA88  0000000096 0000000001 0000000096    Init 0x66EA88  0000000032 0000000001 0000000032    (fragment) (Free Blocks) 0x684FD8  0000000776 0000000004 0000003104    *In-use Packet Header* 0x685AB8  0000000288 0000000001 0000000288    Init 0x68A9B0  0000011660 0000000001 0000011660    DISC specific structure members 0x690A5C  0000000036 0000000004 0000000144    Dot11CACprocess 0x694170  0000000040 0000000001 0000000040    Dot11CACprocess 0x694280  0000000024 0000000007 0000000168    Dot11CACprocess 0x694280  0000000080 0000000001 0000000080    Dot11CACprocess 0x6942F8  0000000024 0000000004 0000000096    Dot11CACprocess 0x697DA0  0000001500 0000000001 0000001500    Crypto requests 0x698CE8  0000000024 0000000001 0000000024    Software engine status 0x0       0000000000 0000002112 0002336152    Pool Summary 0x0       0000000000 0000000048 0002278308    Pool Summary (Free Blocks) 0x0       0000000044 0000002160 0000095040    Pool Summary(All Block Headers)           I/O memory Alloc PC        Size     Blocks      Bytes    What 0xBC058   0000000260 0000000037 0000009620    *Packet Data* 0xBC058   0000000756 0000000032 0000024192    *Packet Data* 0xBC058   0000001680 0000000192 0000322560    *Packet Data* 0xBC058   0000001692 0000000010 0000016920    *Packet Data* 0xBC058   0000002600 0000000030 0000078000    *Packet Data* 0xBC058   0000000028 0000000001 0000000028    (fragment) (Free Blocks) 0xBC058   0000000756 0000000001 0000000756    *Packet Data* (Free Blocks) 0xBC058   0000003428 0000000001 0000003428    (fragment) (Free Blocks) 0xBC058   0000005164 0000000001 0000005164    (coalesced) (Free Blocks) 0xBC058   0000008636 0000000001 0000008636    (coalesced) (Free Blocks) 0xBC058   0000779576 0000000001 0000779576    (coalesced) (Free Blocks) 0x4B6FA8  0000000064 0000000001 0000000064    Init 0x4B6FA8  0000000128 0000000001 0000000128    Init 0x4B6FA8  0000000040 0000000001 0000000040    (fragment) (Free Blocks) 0x684170  0000002004 0000000001 0000002004    Init 0x6855C8  0000000172 0000000004 0000000688    Init 0x0       0000000000 0000000308 0000454176    Pool Summary 0x0       0000000000 0000000007 0000797628    Pool Summary (Free Blocks) 0x0       0000000044 0000000315 0000013860    Pool Summary(All Block Headers) 0x0       0000000000 0000002420 0002790328    Memory Summary 0x0       0000000000 0000000055 0003075936    Memory Summary (Free Blocks) ------------------ show region ------------------ Region Manager:       Start         End     Size(b)  Class  Media  Name 0x00000000  0x00EC87FF    15501312  Local  R/W    main 0x00003000  0x0069BB4F     6916944  IText  R/W    main:text 0x0069BB60  0x0099DBB3     3154004  IData  R/W    main:data 0x0099DBB4  0x00A4AB7F      708556  IBss   R/W    main:bss 0x00A4AB84  0x00EC87FF     4709500  Local  R/W    main:heap 0x00ECB000  0x00FFFFFF     1265664  Iomem  R/W    iomem ------------------ show buffers ------------------ Buffer elements:      499 in free list (500 max allowed)      200488 hits, 0 misses, 0 created Public buffer pools: Small buffers, 104 bytes (total 37, permanent 25, peak 37 @ 01:39:32):      37 in free list (20 min, 60 max allowed)      70384 hits, 4 misses, 0 trims, 12 created      0 failures (0 no memory) Middle buffers, 600 bytes (total 32, permanent 15, peak 33 @ 00:26:32):      30 in free list (10 min, 30 max allowed)      38752 hits, 11 misses, 1 trims, 18 created      0 failures (0 no memory) Big buffers, 1536 bytes (total 10, permanent 5, peak 53 @ 01:01:55):      7 in free list (5 min, 10 max allowed)      22015 hits, 1468 misses, 4380 trims, 4385 created      0 failures (0 no memory) VeryBig buffers, 4520 bytes (total 0, permanent 0):      0 in free list (0 min, 10 max allowed)      0 hits, 0 misses, 0 trims, 0 created      0 failures (0 no memory) Large buffers, 5024 bytes (total 0, permanent 0):      0 in free list (0 min, 5 max allowed)      0 hits, 0 misses, 0 trims, 0 created      0 failures (0 no memory) Huge buffers, 18024 bytes (total 0, permanent 0):      0 in free list (0 min, 2 max allowed)      0 hits, 0 misses, 0 trims, 0 created      0 failures (0 no memory) Interface buffer pools: FastEthernet0 buffers, 1524 bytes (total 192, permanent 192):      168 in free list (0 min, 192 max allowed)      38 hits, 0 fallbacks      8 max cache size, 8 in cache      75903 hits in cache, 14 misses in cache Dot11Radio0 buffers, 2444 bytes (total 30, permanent 30):      26 in free list (0 min, 30 max allowed)      17059 hits, 0 fallbacks
Everyone's tags (2)
1 REPLY
Re: Setting up Multiple SSID's & VLAN
if you remove "encryption mode ciphers aes-ccm tkip" from the radio interface does it help?
it should remain like this:
 no ip address
 no ip route-cache
! encryption vlan 1 mode ciphers aes-ccm tkip ! ssid WLAN_Corporate ! ssid WLAN_HartKitGuest
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
1353
