09-09-2013 08:03 AM - edited 07-04-2021 12:47 AM
I have a question about a wireless bridge connection between 2 Cisco 1310g bridges.
Several subinterfaces are made and going over the wireless connection.
One subinterface has made for public internet access.
The customer wants to shape this to a maximum of 5 mbit.
class-map match-all Internet
match ip precedence 0
policy-map Internet
class Internet
set cos 0
Making and implementing is no problem, but some commando's are accepted but it won't work after showing the output
I applied the commando on the subinterface I created. But after a show run int fa0.xxx only the service-policy remained active.
The current IOS verion is quite old:
c1310-k9w7-mx.123-8.JEA3/c1310-k9w7-mx.123-8.JEA3 |
My question: is it possible to do what I want to achieve? Upgrading these bridges to the latest IOS version will fix it?
I can't find anything in the release notes or any other documents.
Or does anyone have another great idea?
Thanks!
Erik
09-09-2013 09:46 AM
take a look at the below guide for QoS on bridges.
http://www.cisco.com/en/US/docs/wireless/bridge/1400/12.3_8_JA/configuration/guide/p38qos.html
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
09-09-2013 12:22 PM
In the bridge itself you cannot do much since it does not support any action other than "set cos". Here is the extract from above config guides pointed by Stephen. Even other commands accepted, it won't work
"They support only MQC policy-map set cos action"
You should look at traffic shaping where L3 interface defined for that vlan if multiple vlan traverse across the bridge.
Rasika
