Community Member
show client ccx rm <mac> status
Hi there,
I have a WLC 2504 v7.4, AP1602, and a client with CCX v5.
In the WLC, I already enable the CCX Location Measurement from GUI... WIRELESS > 802.11b/g/n > Network
In the WLC, I can see my laptop as a "client" and it shows that my laptop is CCXv5
In the WLC, in the Clients > Detail page, I click the button "Send CCX Req"... wait..then click "Display" wait..wait.. nothing happens.
I then go to the WLC command line, and issue command.... (note that 08:3e:8e:32:19:09 is my laptop wireless adapter MAC)
>show client ccx rm 08:3e:8e:32:19:09 status
Client not in the unicast rm list
What is the "unicast rm list" and how do I put my laptop into the WLC rm list?
Sakul.Tunboonek@itpattana.com
Everyone's tags (4)
Hall of Fame Super Silver
Post the show client detail 08:3e:8e:32:19:09
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Community Member
Hi Scott, thanks and pls find below the result.
(Cisco Controller) >show client detail 08-3E-8E-32-19-09
Client MAC Address............................... 08:3e:8e:32:19:09
Client Username ................................. N/A
AP MAC Address................................... 20:bb:c0:82:ff:80
AP Name.......................................... PSCTH_AP1
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 1
Hotspot (802.11u)................................ Not Supported
BSSID............................................ 20:bb:c0:82:ff:80
Connected For ................................... 256 secs
Channel.......................................... 1
IP Address....................................... 172.16.1.250
Gateway Address.................................. Unknown
Netmask.......................................... Unknown
Association Id................................... 6
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Session Timeout.................................. 1800
Client CCX version............................... 5
Client E2E version............................... No E2E support
Diagnostics Capability........................... Supported
--More-- or (q)uit
S69 Capability................................... Not Supported
QoS Level........................................ Silver
802.1P Priority Tag.............................. disabled
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
WMM Support...................................... Enabled
  APSD ACs.......................................  BK  BE  VI  VO
Power Save....................................... OFF
Current Rate..................................... m7
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,
    ............................................. 12.0,18.0,24.0,36.0,48.0,
    ............................................. 54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
Audit Session ID................................. none
IPv4 ACL Name.................................... none
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
mDNS Status...................................... Disabled
--More-- or (q)uit
mDNS Profile Name................................ none
No. of mDNS Services Advertised.................. 0
Policy Type...................................... N/A
Encryption Cipher................................ None
Protected Management Frame ...................... No
Management Frame Protection...................... No
EAP Type......................................... Unknown
Interface........................................ management
VLAN............................................. 0
Quarantine VLAN.................................. 0
Access VLAN...................................... 0
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 5
      Fast BSS Transition........................ Not implemented
Client Wifi Direct Capabilities:
      WFD capable................................ No
      Manged WFD capable......................... No
      Cross Connection Capable................... No
--More-- or (q)uit
      Support Concurrent Operation............... No
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 377711
      Number of Bytes Sent....................... 2315955
      Number of Packets Received................. 2747
      Number of Packets Sent..................... 3214
      Number of Interim-Update Sent.............. 0
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Id Request Msg Failures...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Request Msg Failures......... 0
      Number of EAP Key Msg Timeouts............. 0
      Number of EAP Key Msg Failures............. 0
      Number of Data Retries..................... 293
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 1
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of RA Packets Dropped............... 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ -47 dBm
--More-- or (q)uit
      Signal to Noise Ratio...................... 49 dB
Client Rate Limiting Statistics:
      Number of Data Packets Recieved............ 0
      Number of Data Rx Packets Dropped.......... 0
      Number of Data Bytes Recieved.............. 0
      Number of Data Rx Bytes Dropped............ 0
      Number of Realtime Packets Recieved........ 0
      Number of Realtime Rx Packets Dropped...... 0
      Number of Realtime Bytes Recieved.......... 0
      Number of Realtime Rx Bytes Dropped........ 0
      Number of Data Packets Sent................ 0
      Number of Data Tx Packets Dropped.......... 0
      Number of Data Bytes Sent.................. 0
      Number of Data Tx Bytes Dropped............ 0
      Number of Realtime Packets Sent............ 0
      Number of Realtime Tx Packets Dropped...... 0
      Number of Realtime Bytes Sent.............. 0
      Number of Realtime Tx Bytes Dropped........ 0
Nearby AP Statistics:
      PSCTH_AP1(slot 0)
        antenna0: 190 secs ago................... -50 dBm
        antenna1: 190 secs ago................... -47 dBm
DNS Server details:
--More-- or (q)uit
      DNS server IP ............................. 0.0.0.0
Assisted Roaming Prediction List details:
Client Dhcp Required:     True
Re: show client ccx rm <mac> status
Have you enabled RM?
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/rrm/config_rrm_chapter_0101.pdf
-Scott
For your information, 2 CCX enabled clients per AP are supported at max. When you issued show client ccx rm status, it revealed , that particular client has not received any unicast request from AP. For more info refer below
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/consolidated/b_cg74_CONSOLIDATED_chapter_010000111.html#ID2083
Community Member
Hi, thanks Scott and Saurav... yes, I have enable the RM. I have followed the docs in your link.. however, seem like the AP still does not send out any unicast request..
note: in Step3 in the document, it guide to issue command >config client location-calibration {enable | disable} client _mac interval_seconds but my WLC_2504 does not support this command.
(Cisco Controller) >config advanced 802.11b ccx location-meas global enable 60
No change - configured values are same as previous
(Cisco Controller) >config advanced 802.11b ccx customize PSCTH_AP1 on
Operation completed successfully
(Cisco Controller) >config advanced 802.11b ccx location-meas ap PSCTH_AP1 enable 60
Cisco AP CCX options set
(Cisco Controller) >config client ?
ccx            Configure Cisco Client Extension(CCX) diagnostic options.
deauthenticate Disconnects a client.
(Cisco Controller) >config client ccx ?
clear-reports  Clear all stored Client Profile Information.
clear-results  Clear All test Results.
default-gw-ping Send request to perform Default Gateway Ping test.
dhcp-test      Send request to perform DHCP test.
dns-ping       Send request to perform DNS Server Ping test.
dns-resolve    Send request to perform DNS Name Resolution test.
get-client-capability Send a request to get Client's Capabilty Info.
get-manufacturer-info Send a request to get Client's Manufactured Info.
get-operating-parameters Send a request to get Client's Current  Operating Parameters.
get-profiles   Send a request to get Client Profiles.
log-request    Send a CCX Log Request.
send-message   Send a message to the Client,
stats-request  Send a CCX Client Statistics Request.
test-abort     Abort the Current test.
test-association Send request to perform Association test.
test-dot1x     Send request to perform 802.1x test.
test-profile   Send request to perform Profile Redirect test.
(Cisco Controller) >show advanced 802.11b ccx global
  802.11b Client Beacon Measurements:
    enabled with (interval=60) seconds
(Cisco Controller) >show advanced 802.11b ccx ap PSCTH_AP1
  802.11b Client Beacon Measurements for Cisco AP:
(Cisco Controller) >show ap ccx rm PSCTH_AP1 status
B Radio
  Beacon Request................................. Disabled
  Channel Load Request........................... Disabled
  Frame Request.................................. Disabled
  Noise Histogram Request........................ Disabled
  Path Loss Request.............................. Disabled
  Interval....................................... 60
  Iteration...................................... 0
                                                   A Radio
(Cisco Controller) >show client ccx rm 08-3E-8E-32-19-09 status
1329
