Show combined coverage between floors on Prime 1.2
I wold like to know if it is possible to show in one the floor map the coverage of Acess Point in the next level, in my case I have floors 7 and 8 where some APs in the floor 8 covers areas in the fllor 7 and viceversa, but I can only the signal of the APs in the floor.
thanks for yur help
1 ACCEPTED SOLUTION
I don't think that is possible. The best way I found to do this does not give you an image view of the coverage but you can look at how the AP's on that floor hear their neighbors based on RSSI.
On your map click an ap and then navigate to the desired band and click the link on the bottom of the popup window "View Rx Neighbors"
1 REPLY
176
