show rogue adnoc detailed
Just want to clarify :  when I look at the below output does it mean that "my wireless" is part of the roque SSID that the AP is seeing  or is  it part fo the configuration on the AP and is the AP's SSID ?
(WiSM-slot4-1) >show rogue adhoc detailed 00:0e:35:63:b8:3e
Adhoc Rogue MAC address.......................... 00:0e:35:63:b8:3e
Adhoc Rogue BSSID................................ 02:0e:35:00:bf:04
State............................................ Contained
Number of APs.................................... 1
First Time Adhoc Rogue was Reported.............. Fri Sep 24 13:47:01 2010
Last Time Adhoc Rogue was Reported............... Tue Sep 28 14:53:02 2010
Reported By
    AP 1
        MAC Address.............................. 00:26:cb:82:98:c0
        Name..................................... JHHS-Test
        Radio Type............................... 802.11g
        Containment Mode......................... ADHOC_DEAUTH
        SSID..................................... My Wireless
        Channel.................................. 11
        RSSI..................................... -15 dBm
        SNR...................................... 79 dB
        Encryption............................... Disabled
        ShortPreamble............................ Enabled
        WPA Support.............................. Disabled
        Last reported by this AP................. Tue Sep 28 14:53:02 2010
1 REPLY
Re: show rogue adnoc detailed
Hello, the SSID highlighted below is mentioning the ssid on which the rogue ad-hoc client is communicating on with another client.
Serge
409
