Silver
Signal Strength -86dB . Is it good?
I am trying to find if our new installation between Cisco 130 Bridges is good or not . Not able to find any documentation to read parameters . Can someone help?
Following is the ouput from the bridge:show dot11 ass all
Address : 001b.2a30.1460 Name : Calgary
IP Address : 192.168.100.99 Interface : Dot11Radio 0
Device : 11g-bridge Software Version : 12.3
CCX Version : NONE
State : Assoc Parent : self
SSID : Calgary VLAN : 0
Hops to Infra : 1 Association Id : 3
Clients Associated: 1 Repeaters associated: 0
Tunnel Address : 0.0.0.0
Key Mgmt type : NONE Encryption : WEP
Current Rate : 6.0 Capability : WMM ShortHdr ShortSlot
Supported Rates : 1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
Voice Rates : disabled
Signal Strength : -86 dBm Connected for : 241 seconds
Signal to Noise : 14 dBm Activity Timeout : 29 seconds
Power-save : Off Last Activity : 1 seconds ago
Apsd DE AC(s) : NONE
Packets Input : 495 Packets Output : 1061
Bytes Input : 49678 Bytes Output : 105053
Duplicates Rcvd : 0 Data Retries : 375
Decrypt Failed : 0 RTS Retries : 51
MIC Failed : 0 MIC Missing : 0
Packets Redirected: 0 Redirect Filtered: 0
Hall of Fame Super Silver
Re: Signal Strength -86dB . Is it good?
I think is all depends on what traffic you are trying to send accross. -86dbm isn't usually that great of a singnal to many. If you take a look at:
You can see your data rate is at 6.0 mbps.
-Scott
Silver
Thanks for the reply fella5.
So how can i improve the Signal Strength?
Any ideas.
Silver
Any ideas.
There are a couple of things. Channel selection might help if there is interference on your current link. You can verify that the alignment is as good as it gets or you can go with an external antenna with a higher gain if the 1300 allows you to have external antennas.
-Scott
184
