Signal Test Tool ...
Hi, i have one question
Anyone knows a tool for measuring signal strength from an AP. I used in the past the Airmagnet, but anybody knows if CISCO have similar tools?
if not, any other tool that not is Airmagent ?
Thanks a lot.
Enrique
Ingeniero de Prpyectos Magenta Computacion
Chile
1 REPLY
Re: Signal Test Tool ...
Cisco has the ACU utily that has Site Survery, Signal Strenght, Link Test, etc. You could also try netstumbler.com, it does not work with Cisco Client Card. If you have used Airmagnet, then the next best tool would be the Fluke Networks WaveRunner.
125
