Single 1131AG AP in a static site - no DHCP.
I have a remote site that would like to add wireless access.  They do not have a domain controller or DHCP, everything is set statically (but on a separate subnet).  There is only 1 PC and 2 laptops.
If I pre-configure an 1131AP with the controller information and a static IP address, will this work?  Would it be better to just give them an autonomous AP?
  • Other Wireless - Mobility Subjects
Re: Single 1131AG AP in a static site - no DHCP.
Yes, if you prime the AP locally, then send it to the site, it should work just fine.  How this sounds, I would go with HREAP for that AP though.  As this is a very small site, you could do IOS as well.  IMHO I'd go IOS for this setup.
HTH,
Steve
*Please remember to rate helpful posts*
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Thanks, I'll give it a try with HREAP.  For managability I'd rather have it tied into the controller rather than using IOS.
311
