single 2.4g vs dual band
what are pros and cons of going with a high density 2.4g vs a dual band antenna?
Everyone's tags (1)
Hall of Fame Super Gold
What pros and cons do you
What pros and cons do you need?  The phrases "high density" and "single band Wi-Fi" don't mix.
Exactly what are you trying to achieve?
I don't know if you should
I don't know if you should consider a 2.4 GHz design for any HD deployment. There simply isn't enough spectrum to properly service the depth of clients and there is no 40 Mhz 802.11n or 802.11ac on 2.4 GHz. You really limit yourself with 3 non overlapping channels.
Hope this helps ..
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
62
