Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Single client associates to wap, pulls DHCP address, but cannot pass any traffic
Hello all!
I'm having a strange issue with a single autonomous WAP that has been configured by another engineer. The topology is as follows: A single autonomous wap services a small site that has wireless only clients on the site. The WAP connects directly to an ASA 5505 in which the wap is connected to a port that is configured for the inside interface of the firewall.
All other clients on the network have no connectivity or problems associating to the WAP, however, recently a single client has reported that they are having connectivity problems. Upon futher investigation by me, I found that the client does indeed successfully associate to the access point, does indeed pull a correct DHCP address that is in the same subnet as the wap, but cannot ping the gateway or the WAP. Additionally, while onsite, I connected my laptop as a wireless client (this is the first association to this wap with my machine), and was able to get connectivity for my machine flawlessly. DHCP is being served via the ASA, and the wireless client with the problem does show up correctly in the ASA's ARP table. The client with the issue does successfully connect to another 1141N at another site with a similar configuration and topology and matching IOS versions on the wap. The Configuration is as follows with some ommisions and address changes:
hostname omitted#sh run
Building configuration...
Current configuration : 1785 bytes
version 12.4
no service pad
service password-encryption
hostname ******hostname omitted*******
enable secret ****omitted*****
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 syslog
dot11 ssid thisisnottherealssid
   authentication open
   authentication key-management wpa version 2
   guest-mode
   mbssid guest-mode
   wpa-psk ascii ****psk omitted****
! username information ommited **
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.2.245 255.255.255.0
no ip route-cache
ip default-gateway 192.168.2.1
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
end
**hostname omitted**#sh dot11 assoc
802.11 Client Stations on Dot11Radio0:
SSID [**ssid omitted**] :
MAC Address    IP address      Device        Name            Parent         State
****MAC OMITTED**** 192.168.2.74    unknown       -               self           Assoc    <------This is the client with the issue
****MAC OMITTED**** 192.168.2.84    ccx-client    -               self           Assoc
****MAC OMITTED**** 192.168.2.81    ccx-client    -               self           Assoc
****MAC OMITTED**** 192.168.2.85    unknown       -               self           Assoc
****MAC OMITTED****192.168.2.75    unknown       -               self           Assoc
****MAC OMITTED**** 192.168.2.69    unknown       -               self           Assoc
****MAC OMITTED**** 192.168.2.76    ccx-client    -               self           Assoc
****MAC OMITTED**** 192.168.2.80    unknown       -               self           Assoc
****MAC OMITTED**** 192.168.2.83    unknown       -               self           Assoc
****MAC OMITTED**** 192.168.2.78    unknown       -               self           Assoc
****MAC OMITTED**** 192.168.2.82    unknown       -               self           Assoc
I know I'm probably missing something here, I just can't quite put my finger on it. I appreciate any assitance that anyone can provide in advance that can help me resolve this issue.
I would also like to add that I placed an interface capture on the inside interface of my ASA which specified traffic for this client's ip address, and was not able to see any traffic in the capture.
Hall of Fame Super Silver
Re: Single client associates to wap, pulls DHCP address, but can
That seems like an client device issue. Maybe a bad card... Try an open SSID and see if he still has problems.
-Scott
Tried the open SSID and it did not work, it did however work when I removed guest-mode from that SSID. One small addendum that I have is that there was a second ssid on the device that was configured but was not shown in the config snippet, that was also in guest mode. The other SSID was not needed so I removed the configuration for that ssid completely. After that, this client started working.
Strange...
401
