snmp traps will not stop
We are getting a ton of snmp "cold start" traps. About every minute or less. I even took the statement out of the configuration to stop the device from sending those traps but they're still coming.
I used the "no snmp-server traps enable snmp coldstart warmstart"
I verified that it was no longer in the config as well. Any help?
Re: snmp traps will not stop
Is this for a specific interface? if so try "no snmp trap link-status" in the interface config.
HTH.
These are coming from our wireless access points. We dont want to turn off all status traps on them either.
Hall of Fame Super Silver
Are your ap's bouncing? I have only seen this when the ap is on the secondary controller and fails to joins its primary.
-Scott
128
