12-18-2008 03:10 PM - edited 07-03-2021 04:54 PM
Currently using WLC 4402 with about a dozen WAPs. I would like to start logging some messages to troubleshoot some association issues. The syslog does not seem adequate for this the issues I am having. I noticed the default SNMP traps but is only holds 255 traps. I have tried to setup an SNMP server to get the traps but I get no data, only OID values. I was successful in getting the MIBs for the OIDs but still not all the data that I see on the brief traps screen.
12-24-2008 10:09 AM
It seems like the Context in SNMPV2 table was not getting intialized properly.
12-24-2008 04:35 PM
Run your LWAPP debugs. Everything you need to know about AP and client association is contained in those logs. SNMP really only helps with WLC to WCS communications.
01-06-2009 11:26 PM
I have tried it with solarwinds and works fine for me. Talking about the traps. But they are too many.
The OID is : 1.3.6.1.4.1.14179.1.1.2.4.1.22
snmp info for polling:
MIB Value Type: Raw Value
Format: None
SNMP Get Type: Get Table
Polling Type: node
On WLC go to Managemnet (top TAB)
Right hand select > SNMP > Traps Control.
In this menu select what traps to need to be logged.
These traps will be shows on the oid polled.
