SNR greater than signal strength?
So a buddy of mine asked me to look into some wireless problems he was having. After doing the standard show dot11 ass all, i saw that several clients had a SNR higher than the signal strength.
IE Signal strength was around -40 but the SNR was in the 50s. That is something i have never seen before. Bug?
1 REPLY
Re: SNR greater than signal strength?
Not sure how this is possible unless there is an issue with the software showing those readings. I would expect to see the noise level high as well.
102
