02-18-2010 02:02 AM - edited 07-03-2021 06:31 PM
We use AIR-LAP-1242AG-E-K9 ap's and WLC 4.2.176.0
Sometimes I have access points who do not accept clients, you also can't see the AP with a wireless sniffer....
When I reboot the AP, it's working fine again !!!
In the WLC the AP and radio's are up, and no error messages I could find so far ...
Anyone who has/had the same problem ?
02-19-2010 10:45 AM
Have you turned on AP logging from the WLC?
>config ap logging syslog level ?
alerts Logging severity level 1.
critical Logging severity level 2.
debugging Logging severity level 7.
emergencies Logging severity level 0.
errors Logging severity level 3.
informational Logging severity level 6.
notifications Logging severity level 5.
warnings Logging severity level 4.
(Cisco Controller) >config ap logging syslog level alerts ?
all Applies the settings to all APs.
(Cisco Controller) >config ap logging syslog level alerts all?
all
All the logs will then be sent to the syslog server in the WLC settings
02-21-2010 11:07 PM
Problem is, we have 300 AP's... and sometimes one of them is having this problem....
Any idea, if I do this, what I should be looking for ? because this will be a really a lot of data ....
02-19-2010 04:33 PM
Do you have any idea how many clients were already associated to a particular AP before the same AP will refuse to take additional clients?
By default on the 4.X, the Max Client association is set to 25 (max is 75).
02-21-2010 11:07 PM
Max 15 clients.... we have a nice density of AP's ;-)
02-21-2010 07:32 PM
Do you have aggressive load balancing enabled on the controller?
02-21-2010 11:05 PM
Aggressive Load Balancing is disabled.
