Community Member
SSID with WebAuth and iPhone Issues
Cisco Wireless Users,
Have anyone setup a basic SSID with WebAuth using LDAP/ACS for authentication working with the iPhone? I been having a couple of users getting the “Unable to join the network” error message. Have you gotten this error and if so what did you do for the fix? I'm running version 5.0.148.0 on my 4402's.
Hall of Fame Super Silver
Re: SSID with WebAuth and iPhone Issues
What type of encryption are you using.... is it ope with WebAuth. I have not had an issues with iPhones not being able to connect to WebAuth on any of my recent installs.... I use my iPhone for testing so I know it works.
I also think you should either downgrad to 4.2.176 or upgrade to 5.1 or 5.2. 5.0 is one of the worse codes out there.
-Scott
Community Member
There is no encryption on this SSID, it seems that I just have to update to the latest code. Thanks
248
