Community Member
Standalone WAP for Outdoor / Weatherproof
Can any one recommend a good model of a WAP works as standalone for weatherproof / outdoor use ?
Thanks.
Hall of Fame Super Silver
Re: Standalone WAP for Outdoor / Weatherproof
You can look at 1300 or 1400 access point. I believe they are EOL but you can still find them from a refurb reseller or on ebay.
-Scott
Community Member
Thanks Scott. I already looked at these models and since they are EOL I didn't want to buy them . Know of any new models that work as standalone ?
The only other one is the mesh APs. The 1520's and the 1552's.
-Scott
Community Member
Scott - Thanks a lot
The other solution you may take rather than using the MESH APs (that can not be set as autonomous) is to use a plastic/wooden box to keep the AP safe inside.
Rating useful replies is more useful than saying "Thank you"
Community Member
Amjad - I am looking at getting a 3500 series and use a Oberon casing model # 1026-00  . This is actually a cisco recommended model of a NEMA enclosure.
482
