Strange error message with Casio Devices on Local PEAP Auth
Dear all,
I'm getting the following error message when doing a debug client on the controller:
EAPOL-key M2 with invalid WPA IE received from mobile 00:21:e8:12:76:cb
The client off course can not connect to the network sucessfully then....
Has anyone seen this message or can explain what it means.
regards
Rupert
Re: Strange error message with Casio Devices on Local PEAP Auth
Rupert,
Interesting ... Do you have other devices on the SSID and authenticating ? What model device is it ?
Can you connect the device with WPA PSK?
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
This means.. the invalid MIC is getting generated, which is not allowing the connection.. invalid MIC issues are resolved by upgrading the drivers software to the latest.
Surendra
Hello Rupert,
Please mark the Question as Answered, if the provided information by George and Surendra is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Thanks & Regards
293
