Support for 1000 series in 5.0.148.0 ?
I just read the release notes for WLC update 5.0.148.0 and I saw this line:
Cisco Aironet 1000 Series Access Points-The 1000 series access points are not supported for use with controller software release 5.0.148.0
Our entire network consists of 1010 and 1020 AP's (17 of them), does this mean that I can't update to 5.0.148.0 and that I'm stuck on 4.1.185.0 forever, or until I replace all of my APs ?
If Yes, what is the best AP to update to, to ensure a long lifespan, and is it worth the cost ?
/Dan
Re: Support for 1000 series in 5.0.148.0 ?
We have exactly the same problem and i can confirm 5.x doesnt work with AP1010's.
The best you can do is upgrade to 4.2.112.0 which I had to roll back to and works fine.
We run mixed 1200's and 1000's and the 1200's run fine on 5.x
the 1000 series are vxworks based and are no longer supported under 5.x code. EOS/EOL for the 1000 series was announced 9/07.
If you want n support, go with the 1252 radios, otherwise go for the 1242 radios. Those two models are the "long term" Cisco models.
We faced the same dilemma, but I do not see a very compelling reason to upgrade to 5.x yet.
Hello Ericgarnel
A couple of follow ups on that:
1. I see that 1252 has 6 antennas, does this mean that these APs have a lot better coverage than 1010 and 1020 and I can get away with less APs ?
2. We have a WLC4402-25 today and we're using one GB port on it. If we would change to 1252 APs the theoretical bandwitdh would be approx six times greater, will a 4402 be enough to satisfy the needs even if we connect the second GB port or do we have to upgrade that aswell ?
/Dan
143
