Syslog server for access points
brock0150
On the controller, when you look at an access points config. There is the syslog server for the access point with the default ip address of 255.255.255.255. I was wondering if there was any way to disable the syslog server for the access points. The only thing I've found so far is that the ip address of the syslog server can be changed.
didyap
Level 6
Level 6
To remove a syslog server, use the no logging host global configuration command, and specify the syslog server IP address. To disable logging to syslog servers, enter the no logging trap global configuration command.
i am not sure if "no" command works.
but on 5.2 ver
config logging trap disable global
disbale/ enable is the key to set the ip address for syslog server
