Testing MobileIP and not sure if I will need a FA or not
g-davidson
I'm trying to get MobileIP working on a 2621 router. I've had some succes, but it doesn't work right just yet. I can get the MN to move from its home network into a foreign network just fine, but then the MN won't move back into its home network after leaving the foreign network until 10 min. later, which is unacceptable for what it will be used for. What it's going to be used for is to allow a MN to move through multiple subnets that will all be connected to the same router. However, if I issue the "clear ip route *" command, the MN immediately jumps back into its home network. The following is the configuration I'm currently using for testing.
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
memory-size iomem 10
ip subnet-zero
call rsvp-sync
interface Ethernet0/0
ip address 10.2.3.1 255.255.255.0
ip mobile arp
ip mobile foreign-service
ip mobile registration-lifetime 3
half-duplex
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Ethernet0/1
ip address 10.2.4.1 255.255.255.0
ip mobile arp
half-duplex
router mobile
ip classless
ip http server
ip pim bidir-enable
ip mobile home-agent lifetime 3
ip mobile host 10.2.3.3 10.2.3.254 interface Ethernet0/0 lifetime 3
ip mobile host 10.2.4.3 10.2.4.254 interface Ethernet0/1 lifetime 3
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
login
no scheduler allocate
end
Any help will be greatly appreciated. Thanks.
George
jbohla
Proxy mobile IP feature works in conjunction with the Mobile IP feature in IOS. When you enable proxy mobile IP on your access point and on your wired network, the access point helps client devices from other networks remain connected to their home networks.Mobile IP provides users the freedom to roam beyond their home subnets while maintaining their home IP addresses. This enables transparent routing of IP datagrams to mobile users during their movement, so that data sessions can be initiated to them while they roam.
To enbale proxy mobile ip,the following links will be helpful to you:
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_installation_and_configuration_guide_chapter09186a0080101c31.html
To get some configuration guidelines about mobileip u can use the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t1/mobileip.htm
