the AP can be Registerd only whith one port
Hi;
the APs can be registerd only whith one WCS port witch connect to one switch, if i connect they other port to other switch the APs unregstred immediately.
i have  install the WCS 4404 with 4 port and i want to connect eatch WCS port to one switch ( i have 4 Switchs ), i have install it on LAG and i have the management intreface and the AP managed interrface on the same network 10.71.0.0 255.255.240.0. and yhe services interface on 10.203.28.14.
i need your help.
Bronze
Re: the AP can be Registerd only whith one port
You'll either have to create multiple AP Manager interfaces (one for each switch) and not do LAG, or your switches would need to be "stackable" like the 3750's so you can create a port channel across multiple physical switches (but a single logical one).  Hope that helps. - John
thanks for your answer,
i create multiple AP Manager interfaces one for each switch with no LAG ( Pièces jointes).
Best Regard
Hall of Fame Super Gold
Each of the distribution ports should go to one virtual switch (or stacked) like a 4XXX, 6XXX, 3750, 2975 or 2960S.  Going to different switch is not supported.
can you take a look for this Schema in the pièces jointes.
Best Regard
271
