Bronze
Too many retransmission/duplicate ACKs in wireless, is it normal?
We use Cisco LWAPP wireless. I have seen many TCP retransmission and duplicate ACKs at clients. I do not see those in our wired enviroment. Is it normal for wireless? Anyone else see this issue in your wireless network as well? Thanks!
1 REPLY
Re: Too many retransmission/duplicate ACKs in wireless, is it no
This quick article may be of help to you..
but in short, depending on where you're sniffing from, it's pretty normal for a larger amount due to the way the technology works. However, poor design can increase them to levels that are "bad".
http://www.wildpackets.com/support/additional_resources/2004_05
627
