Transmit Power Levels after upgrading to 6.0.188.0
I have recently upgraded several clients from 4.2.176.0 to 6.0.188.0 and noticed that after the upgrades the Transmit Power Levels appear to have gone to a value lower than they were on the previous code. Has anyone noticed or experienced this? Was there a change to the DTPC Algorithm?
Any thoughts would be greatly appreciated.
1 ACCEPTED SOLUTION
Gold
Re: Transmit Power Levels after upgrading to 6.0.188.0
There were changes to the RRM algorithm between the version you mentioned so it is very possible that some of the AP's are now showing different values.
Gold
Thanks for the input.
Any upgrade ?
I've read that the algorithm is changed ( primary the behaviour related to the DCA selection ) and doesn't follow anymore the following rule:
"The Group Leader checks if another channel schema will result in a 5 dB better SNR on the worst performing AP"
Have You more informations ?
regards
Luigi
401
