transmitter power error - Cisco 1602E
on the web interface, there is an error indicated for the transmitter power.
I have no idea whats wrong.
The follwing supported dual band Cisco Antenna's are in use.
AIR-ANT2524DW-R=
Here is my config:
! Last configuration change at 23:21:26 +0100 Wed Mar 5 2014 by Thomas
! NVRAM config last updated at 23:21:26 +0100 Wed Mar 5 2014 by Thomas
version 15.2
no service pad
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname ap-2
logging rate-limit console 9
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone +0100 1 0
no ip cef
no dot11 igmp snooping-helper
dot11 syslog
dot11 ssid TOM
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 xxxxx
dot11 ssid TOM2
   authentication open
   guest-mode
dot11 guest
username xxxxx privilege 15 password 7 xxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid TOM
antenna gain 2
stbc
beamform ofdm
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid TOM2
antenna gain 4
peakdetect
no dfs band block
stbc
beamform ofdm
channel width 40-above
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip forward-protocol nd
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
no cdp run
bridge 1 route ip
line con 0
line vty 0 4
transport input all
sntp server 192.168.2.66
sntp broadcast client
end
Thomas Neumann
VIP Purple
Hi Thomas,
Is this impact your wireless set up ? Are you able to connect to wireless or not ?
What is the exact error message ?
Rasika
Hi Rasika,
the Ap works and im able to connect both 2,4 Ghz and 5Ghz.
The Range of my 1024 is better than the 1602 with external Antennas.
The exact error message in Web-Config ist: Transmitter Power - error.
Thomas
Hall of Fame Super Silver
Re: transmitter power error - Cisco 1602E
I would make a few changes also. Remove TKIP from the encryption. If you use WPA2 then you should match that up with AES. If you were to use WPA then you use TKIP. Also I would remove the antenna gain from each of the radios
Example:
ssid TOM2
no antenna gain 4
-Scott
Hello Scott,
i made these changes but the error massage remains.
Thomas
Can you post a screen shot of the error?
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Hello Scott,here is the
Hello Scott,
here is the screenshot.
Thomas
329
