Turn off LEDs on AP 1240, etc
Hi folks I need to turn off all the leds on the aps we have installed as they are students sleeping quarters and some students are complaing the leds are keeping thme awake does anyone know how to turn the leds off completlely either via a software command or hardware thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Turn off LEDs on AP 1240, etc
Hi Henry,
Give this a try;
config ap led-state
To enable or disable the LED-State for an access point, use the config ap led-state command.
config ap led-state {enable | disable} {Cisco_AP | all}
Syntax Description
config
Display configurations.
ap
Advanced parameters.
led-state
Enable or disable the LED-State for an access point.
{enable | disable}
Enable or disable the access point's LED-State.
{Cisco_AP | all}
Name of a Cisco lightweight access point or all to specify all access points.
http://www.cisco.com/en/US/docs/wireless/controller/4.1/command/reference/clic1.html#wp2384867
Hope this helps!
Rob
Hi Henry,
Give this a try;
config ap led-state
Syntax Description
config
ap
led-state
{enable | disable}
{Cisco_AP | all}
Hope this helps!
Rob
thanks mate it worked
Hi Henry,
Good stuff! You are most welcome my friend.
Cheers,
Rob
1697
