Turn off Status LED on LWAP 1130
Hi there,
We have mounted some access points in a couple of cinemas and we are concerned that the lights on the AP's will be a distraction. Does any one know if it's possible to turn off the status LED on the face of the Access Point, and how to do it?
Thanks!
Mike.
1 REPLY
Hall of Fame Super Red
Re: Turn off Status LED on LWAP 1130
Hi Mike,
Most possible my friend :)
config ap led-state
To enable or disable the LED-State for an access point, use the config ap led-state command.
config ap led-state {enable | disable} {Cisco_AP | all}
Syntax Description
config
Display configurations.
ap
Advanced parameters.
led-state
Enable or disable the LED-State for an access point.
{enable | disable}
Enable or disable the access point's LED-State.
{Cisco_AP | all}
Name of a Cisco 1000 Series lightweight access point or all to specify all access points.
http://www.cisco.com/en/US/docs/wireless/controller/4.1/command/reference/clic1.html#wp2384867
Hope this helps!
Rob
789
