11-15-2011 06:04 PM - edited 07-03-2021 09:04 PM
I have a customer who wants to have 2 seperate customized captive portal pages, 1 for a passthru WLAN and 1 for an authentication. I know the Cisco default page changes based on the layer 3 security, but to my knowledge, once you set the WebAuth to a custom page, you can only have 1 page. Is there any way to have two seperate custom pages? Thanks for any input!
Solved! Go to Solution.
11-15-2011 06:32 PM
I believe in 5.x they started with a feature "Over-ride Global" for webauth. Now the only way this can work is you need to bundle the pages together that is no more than 1 meg. In the WLAN SSID Layer 3 tab, you choose Web Policy and then Over-ride Global Config. There you can hoose yor html file for that SSID.
https://supportforums.cisco.com/docs/DOC-13954#Small_trick_with_override_global_config_
11-15-2011 06:32 PM
11-15-2011 07:37 PM
That was the ticket! Thanks Scott!
11-15-2011 07:40 PM
No problem:)
Sent from my iPhone
