Community Member
Unable to get a DHCP address via Wireless C871W
I have configured the c871 for wirless. I have one ssid attached to vlan 1. I have set up a dhcp pool which works, beacuse I can grab an IP when hard connected. I can connect to the AP, but am not issued an IP. Included is a config form this AP with the important sections.
Frank
1 REPLY
Silver
Re: Unable to get a DHCP address via Wireless C871W
If you are having problems with an IP-based management connection (telnet or browser) the bridge will, by default, try to get an address via DHCP. If it can't, the address for the bridge will be 10.0.0.1 until a different one is assigned manually or the DHCP issue is resolved.
140
